Toploong cnc plasma laser cutting machine
Hello, I’m new to the forum.
I wanted to use the software with a plasma cutter from TOPLOONG CNC PLASMA LASER CUTTING MACHINE. Does anyone know this machine and know if it can use the generated G-code?
Thanks for your reply.
Happy Easter
More specifically, what type of machine is this machine similar to?
And the next question when trying it out:
I have a number as a DXF drawing, and SC displays many layers. However, I can only select one for cutting. How can I merge layers in a DXF drawing?
Layers can be merged via sheeetcam menu Mode-‘Edit contours’, then right click on the drawing pallet to view the context menu, then ‘Select all’ layers, then ‘Move to layer’ and name the layer in which to combine.
However, it is usually best to manage layers in your CAD program as you design the drawing.
See also this sheetcam intro info…
