sheetcam not creating code, Help?
H guys, ive only been using sheetcam for a few months and this is the first issue that i have had with it. when i run the post processor, it tells me that everything is fine and that sheetcam has created the g-code for me. when i try to bring it up into my mach3, for some reason it has no code and i can see that there is no part. any help would be greatly appreciated. THANKS
In Mach3 make sure you are trying to open the correct file type. For instance if SheetCam is creating ‘.tap’ files you must make sure the ‘files of type’ box in Mach3’s file open dialog is set to ‘All files’ or *.tap.
thank you for the response, sheet cam is exporting in a tap format. i have tried opening in tap and all files into mach 3. im not getting anything
This is an example of the code it is giving me:
N0010 (Filename: attemptthreeuntitled.tap)
N0020 (Post processor: Mach3 plasma pauses.scpost)
N0030 (Date: 11/10/2016)
N0040 G20 (Units: Inches)
N0050 G53 G90 G91.1 G40
N0060 F1
N0070 S500
N0080 (Part: attemptthreeuntitled)
N0090 M05 M30
i tested mine and everything worked fine
N0010 (Filename: bat small.tap)
N0030 (Date: 14/10/2016)
N0040 G21 (Units: Metric)
N0060 F1
N0070 S500
N0080 (Part: bat small)
N0090 (Operation: No Offset, Default Layer, T1: thick)
N0100 M06 T1 F600 (thick)
N0110 G00 Z10.0000
N0120 X134.5002 Y145.1120
N0130 Z4.0000
N0140 M03
N0150 G04 P3
N0160 G01 Z3.0000 F100
N0170 X134.0478 Y150.0914 F600
N0180 G04 P0.25
N0190 X124.2189 Y149.1984
N0200 G03 X121.8121 Y168.1494 I-241.1275 J-20.9959 F600.0
N0210 G02 X122.7543 Y171.7491 I4.6150 J0.7153
N0220 G03 X122.7061 Y186.5486 I-16.1707 J7.3471
N0230 G02 X119.8560 Y200.9055 I14.1084 J10.2621
N0240 X129.0795 Y205.9365 I10.8121 J-8.8517
N0250 X140.1478 Y206.4956 I7.0004 J-28.7513
N0260 X145.9615 Y199.6198 I-2.2715 J-7.8163
N0270 X144.6758 Y191.0670 I-14.9570 J-2.1246
N0280 G03 X138.4558 Y179.6814 I37.3757 J-27.8104
N0290 X138.9030 Y174.9299 I5.8322 J-1.8479
N0300 X142.7461 Y166.7370 I30.8576 J9.4769
N0310 G02 X145.6529 Y161.0910 I-22.5195 J-15.1654
N0320 G03 X151.7722 Y144.0569 I146.7311 J43.0951
N0330 G02 X154.4382 Y126.0754 I-83.4902 J-21.5665
N0340 X150.9677 Y113.3614 I-90.1630 J17.7809
N0350 X145.9523 Y109.4010 I-6.3729 J2.9147
N0360 G01 X142.0323 Y123.6458 F600
N0370 G04 P0.25
N0380 X137.2116 Y122.3193
N0390 G04 P0.25
N0400 X140.9700 Y108.6618
N0410 G02 X128.3073 Y109.8229 I-4.1532 J24.3351 F600.0
N0420 X124.7699 Y114.9802 I4.9669 J7.1987
N0430 G03 X124.6012 Y144.2128 I-241.6785 J13.2223
N0440 G01 X134.5002 Y145.1120 F600
N0450 M05
N0460 G00 Z10.0000
N0470 X163.5676 Y141.7411
N0480 Z4.0000
N0490 M03
N0500 G04 P3
N0510 G01 Z3.0000 F100
N0520 G02 X162.8496 Y142.3508 I0.2342 J1.0033 F600.0
N0530 X156.3372 Y187.8417 I3941.9346 J587.5323
N0540 G01 X163.6745 Y189.0581 F600
N0550 G04 P0.25
N0560 X162.8568 Y193.9906
N0570 G04 P0.25
N0580 X155.8153 Y192.8233
N0590 G03 X148.7495 Y232.8821 I-346.6406 J-40.4896 F600.0
N0600 G02 X150.1902 Y239.1976 I5.7081 J2.0199
N0610 G03 X150.0155 Y247.6700 I-6.5344 J4.1033
N0620 G02 X149.9247 Y250.5454 I2.9853 J1.5334
N0630 X151.3781 Y252.5578 I6.3066 J-3.0237
N0640 X153.8843 Y252.2617 I0.9505 J-2.7090
N0650 G03 X158.2805 Y245.3194 I45.5004 J23.9498
N0660 G02 X158.7853 Y241.3874 I-3.0622 J-2.3916
N0670 X156.9518 Y237.4073 I-13.3694 J3.7465
N0680 G03 X156.4920 Y229.0256 I25.9657 J-5.6278
N0690 G02 X164.9095 Y220.1425 I-71.4436 J-76.1287
N0700 G03 X193.4056 Y194.3759 I259.7454 J258.6201
N0710 X200.2802 Y193.3886 I4.0645 J3.8734
N0720 G02 X209.8007 Y199.8520 I15.4864 J-12.5676
N0730 X213.9058 Y197.1447 I0.4327 J-3.8097
N0740 G01 X228.3600 Y153.2551 F600
N0750 G02 X224.1885 Y141.1291 I-11.2868 J-2.8977 F600.0
N0760 G01 X220.3247 Y151.1680 F600
N0770 G04 P0.25
N0780 X215.6585 Y149.3721
N0790 G04 P0.25
N0800 X219.6295 Y139.0546
N0810 G04 P0.25
N0820 X219.0758 Y138.9121
N0830 G02 X217.6740 Y139.4370 I-0.0000 J2.1343 F600.0
N0840 G03 X186.0553 Y153.9362 I-39.8771 J-45.2354
N0850 X164.4812 Y141.9700 I-3.0910 J-19.8583
N0860 G02 X163.5676 Y141.7411 I-0.6795 J0.7744
N0870 M05
N0880 G00 Z10.0000
N0890 X200.8735 Y109.9222
N0900 Z4.0000
N0910 M03
N0920 G04 P3
N0930 G01 Z3.0000 F100
N0940 X191.5917 Y99.4208 F600
N0950 G02 X178.8172 Y110.8089 I70.9368 J92.4316 F600.0
N0960 X178.6123 Y116.2536 I5.1983 J2.9219
N0970 X180.2893 Y119.2163 I9.8739 J-3.6330
N0980 G03 X164.2388 Y130.1814 I-59.0972 J-69.2756
N0990 G02 X164.3194 Y131.4920 I0.7411 J0.6122
N1000 X195.2995 Y143.0924 I31.8781 J-37.9656
N1010 X219.8651 Y131.4920 I-0.3671 J-32.5882
N1020 G01 X220.5475 Y130.6731 F600
N1030 G02 X234.3316 Y104.8792 I-66.1035 J-51.9052 F600.0
N1040 G03 X246.1418 Y95.2316 I13.0092 J3.8729
N1050 X254.8260 Y97.4769 I-1.7868 J24.8275
N1060 G02 X257.4645 Y96.8955 I0.9819 J-1.8220
N1070 X258.0290 Y94.4044 I-1.1777 J-1.5764
N1080 G03 X256.1515 Y92.3895 I3.1432 J-4.8111
N1090 G02 X262.6750 Y91.7293 I2.3542 J-9.2968
N1100 X263.6467 Y87.2653 I-1.1916 J-2.5972
N1110 X258.0695 Y84.1522 I-9.5870 J10.6230
N1120 G03 X251.0298 Y68.2294 I13.0672 J-15.2949
N1130 X246.8275 Y60.5037 I4.7396 J-7.5838
N1140 G02 X245.0043 Y54.9694 I-14.1999 J1.6105
N1150 X241.5698 Y55.4703 I-1.2496 J3.4574
N1160 X235.6766 Y60.2652 I13.4306 J22.5257
N1170 G01 X234.5934 Y61.5235 F600
N1180 G02 X230.4460 Y68.7834 I20.4070 J16.4725 F600.0
N1190 G03 X223.0217 Y83.8940 I-187.3001 J-82.6469
N1200 X219.2027 Y86.5339 I-3.8190 J-1.4426
N1210 G02 X206.1010 Y89.9134 I2.6446 J37.3384
N1220 X195.6394 Y96.4507 I56.4275 J101.9390
N1230 G01 X204.6197 Y106.6111 F600
N1240 G04 P0.25
N1250 X200.8735 Y109.9222
N1260 M05
N1270 G00 Z10.0000
N1280 X191.3490 Y50.8266
N1290 Z4.0000
N1300 M03
N1310 G04 P3
N1320 G01 Z3.0000 F100
N1330 G03 X197.0312 Y45.6691 I8.8992 J4.0957 F600.0
N1340 X222.0118 Y46.2805 I10.1023 J97.8702
N1350 X229.5331 Y53.5073 I-3.8948 J11.5808
N1360 X229.5404 Y54.9502 I-2.3791 J0.7334
N1370 G01 X229.4480 Y55.6298 F600
N1380 G04 P0.25
N1390 X213.0489 Y52.9866
N1400 G04 P0.25
N1410 X212.2533 Y57.9227
N1420 G04 P0.25
N1430 X228.9132 Y60.6080
N1440 G04 P0.25
N1450 X228.8913 Y60.8783
N1460 G03 X228.8891 Y61.5570 I-2.0866 J0.3327 F600.0
N1470 X224.9008 Y66.1838 I-6.5034 J-1.5736
N1480 X211.7083 Y66.4074 I-7.0308 J-25.5251
N1490 G02 X202.2611 Y65.5130 I-7.8109 J32.1629
N1500 X199.1038 Y70.8303 I6.5186 J7.4666
N1510 G03 X197.3168 Y74.7925 I-5.1010 J0.0835
N1520 G02 X193.7839 Y80.9639 I6.2918 J7.6988
N1530 G03 X192.3528 Y88.9689 I-55.3057 J-5.7566
N1540 X180.0547 Y98.4496 I-13.6817 J-5.0308
N1550 X178.3435 Y91.3155 I0.0629 J-3.7874
N1560 G02 X185.3646 Y84.9641 I-4.9420 J-12.5195
N1570 X185.6866 Y75.4475 I-26.6506 J-5.6654
N1580 X183.1934 Y74.5548 I-1.6028 J0.5485
N1590 X174.8083 Y78.9570 I27.3425 J62.2678
N1600 G03 X171.7851 Y77.3736 I-0.9802 J-1.8063
N1610 X173.7976 Y72.8122 I7.4223 J0.5499
N1620 G02 X178.8063 Y68.6531 I-13.6157 J-21.4928
N1630 G03 X180.8929 Y66.1224 I3.7204 J0.9420
N1640 G02 X187.2254 Y61.4276 I-0.3282 J-7.0609
N1650 G03 X191.1254 Y50.7819 I220.3617 J74.6896
N1660 M05
N1670 G00 Z10.0000
N1680 X174.3942 Y35.3482
N1690 Z4.0000
N1700 M03
N1710 G04 P3
N1720 G01 Z3.0000 F100
N1730 X174.5053 Y35.2622 F600
N1740 M05
N1750 G00 Z10.0000
N1760 X150.0999 Y51.2825
N1770 Z4.0000
N1780 M03
N1790 G04 P3
N1800 G01 Z3.0000 F100
N1810 X145.1045 Y51.0713 F600
N1820 G04 P0.25
N1830 X145.5278 Y41.0616
N1840 G02 X137.7849 Y41.1084 I-3.5052 J60.5609 F600.0
N1850 G03 X133.7769 Y52.5743 I-15.3440 J1.0698
N1860 G02 X125.6976 Y63.9291 I16.2183 J20.0918
N1870 X126.5710 Y79.7603 I28.2544 J6.3808
N1880 X146.8068 Y99.2440 I28.7789 J-9.6395
N1890 X167.0426 Y79.7603 I-8.5431 J-29.1232
N1900 X167.9160 Y63.9291 I-27.3810 J-9.4504
N1910 X159.8366 Y52.5743 I-24.2977 J8.7369
N1920 G03 X155.7958 Y42.5445 I11.3360 J-10.3960
N1930 G02 X150.5111 Y41.5571 I-13.7733 J59.0779
N1940 G01 X150.0999 Y51.2825 F600
N1950 M05
N1960 G00 Z10.0000
N1970 X112.5230 Y34.2859
N1980 Z4.0000
N1990 M03
N2000 G04 P3
N2010 G01 Z3.0000 F100
N2020 X121.7933 Y28.6614 F600
N2030 G04 P0.25
N2040 X119.1998 Y24.3869
N2050 G04 P0.25
N2060 X109.9733 Y29.9848
N2070 G03 X109.5104 Y23.3286 I10.1097 J-4.0473 F600.0
N2080 X122.8477 Y15.0894 I17.2012 J12.9301
N2090 G02 X125.5310 Y13.1932 I-0.1885 J-3.1133
N2100 G03 X131.0778 Y1.5722 I171.1181 J74.5426
N2110 G01 X137.1239 Y1.4253 F600
N2120 G04 P0.25
N2130 X132.8610 Y14.1275
N2140 G04 P0.25
N2150 X137.6010 Y15.7183
N2160 G04 P0.25
N2170 X142.4755 Y1.1938
N2180 G04 P0.25
N2190 X147.5211 Y0.8879
N2200 G04 P0.25
N2210 X154.3448 Y15.8633
N2220 G04 P0.25
N2230 X158.8946 Y13.7901
N2240 G04 P0.25
N2250 X152.8270 Y0.4742
N2260 G04 P0.25
N2270 X157.8053 Y0.0000
N2280 G02 X165.5455 Y10.7455 I92.6664 J-58.5885 F600.0
N2290 X168.2734 Y12.1765 I2.3262 J-1.1188
N2300 G03 X181.2333 Y20.5772 I-0.7119 J15.2954
N2310 X181.9605 Y23.6244 I-4.4331 J2.6683
N2320 X181.6154 Y26.2636 I-13.5271 J-0.4267
N2330 G01 X172.1238 Y22.1139 F600
N2340 G04 P0.25
N2350 X170.1209 Y26.6950
N2360 G04 P0.25
N2370 X179.6027 Y30.8404
N2380 G03 X170.3340 Y36.5974 I-11.1694 J-7.6427 F600.0
N2390 X166.3168 Y34.8528 I0.3106 J-6.2128
N2400 G02 X147.3689 Y29.2719 I-18.8815 J29.1492
N2410 G01 X147.2527 Y21.6052 F600
N2420 G04 P0.25
N2430 X142.2534 Y21.6810
N2440 G04 P0.25
N2450 X142.3741 Y29.6426
N2460 G02 X128.1717 Y35.1040 I5.0612 J34.3594 F600.0
N2470 G03 X123.5390 Y37.8905 I-7.9157 J-7.9157
N2480 X118.5639 Y38.1141 I-2.7545 J-5.8266
N2490 X112.4148 Y34.2011 I16.3789 J-32.5262
N2500 M05
N2510 G00 Z10.0000
N2520 X72.9919 Y50.8266
N2530 Z4.0000
N2540 M03
N2550 G04 P3
N2560 G01 Z3.0000 F100
N2570 G02 X67.3096 Y45.6691 I-8.8992 J4.0957 F600.0
N2580 X42.3290 Y46.2805 I-10.1023 J97.8702
N2590 X34.8077 Y53.5073 I3.8948 J11.5808
N2600 X34.8005 Y54.9502 I2.3791 J0.7334
N2610 G01 X34.8929 Y55.6298 F600
N2620 G04 P0.25
N2630 X51.2919 Y52.9866
N2640 G04 P0.25
N2650 X52.0875 Y57.9227
N2660 G04 P0.25
N2670 X35.4276 Y60.6080
N2680 G04 P0.25
N2690 X35.4496 Y60.8783
N2700 G02 X35.4517 Y61.5570 I2.0866 J0.3327 F600.0
N2710 X39.4401 Y66.1838 I6.5034 J-1.5736
N2720 X52.6326 Y66.4074 I7.0308 J-25.5251
N2730 G03 X62.0798 Y65.5130 I7.8109 J32.1629
N2740 X65.2371 Y70.8303 I-6.5186 J7.4666
N2750 G02 X67.0241 Y74.7925 I5.1010 J0.0835
N2760 G03 X70.5570 Y80.9639 I-6.2918 J7.6988
N2770 G02 X71.9880 Y88.9689 I55.3057 J-5.7566
N2780 X84.2862 Y98.4496 I13.6817 J-5.0308
N2790 X85.9974 Y91.3155 I-0.0629 J-3.7874
N2800 G03 X78.9763 Y84.9641 I4.9420 J-12.5195
N2810 X78.6543 Y75.4475 I26.6506 J-5.6654
N2820 X81.1474 Y74.5548 I1.6028 J0.5485
N2830 X89.5325 Y78.9570 I-27.3425 J62.2678
N2840 G02 X92.5557 Y77.3736 I0.9802 J-1.8063
N2850 X90.5433 Y72.8122 I-7.4223 J0.5499
N2860 G03 X85.5346 Y68.6531 I13.6157 J-21.4928
N2870 G02 X83.4479 Y66.1224 I-3.7204 J0.9420
N2880 G03 X77.1154 Y61.4276 I0.3282 J-7.0609
N2890 G02 X73.2155 Y50.7819 I-220.3617 J74.6896
N2900 M05
N2910 G00 Z10.0000
N2920 X51.6896 Y55.4539
N2930 Z4.0000
N2940 M03
N2950 G04 P3
N2960 G01 Z3.0000 F100
N2970 X51.7117 Y55.4503 F600
N2980 M05
N2990 G00 Z10.0000
N3000 X42.6088 Y36.7585
N3010 Z4.0000
N3020 M03
N3030 G04 P3
N3040 G01 Z3.0000 F100
N3050 G02 X46.8013 Y32.4262 I-5.1030 J-9.1332 F600.0
N3060 G03 X53.7190 Y28.0939 I10.1059 J8.4478
N3070 G02 X60.7765 Y27.1856 I-17.7847 J-166.0429
N3080 X62.5524 Y19.2802 I-4.7850 J-5.2271
N3090 G01 X62.4711 Y18.7426 F600
N3100 G04 P0.25
N3110 X52.8955 Y20.2959
N3120 G04 P0.25
N3130 X52.0949 Y15.3606
N3140 G04 P0.25
N3150 X61.8616 Y13.7763
N3160 G04 P0.25
N3170 X61.6021 Y10.5597
N3180 G02 X55.4659 Y5.8735 I-5.3911 J0.6986 F600.0
N3190 G03 X42.9582 Y6.7120 I-16.1680 J-147.4666
N3200 G02 X30.2408 Y17.5427 I9.0879 J23.5526
N3210 X27.1662 Y28.5132 I15.0523 J10.1345
N3220 X30.3106 Y32.5660 I4.5859 J-0.3118
N3230 G03 X32.4169 Y32.7223 I0.3477 J9.5827
N3240 G01 X35.7214 Y25.0653 F600
N3250 G04 P0.25
N3260 X40.3120 Y27.0464
N3270 G04 P0.25
N3280 X36.9262 Y34.8918
N3290 G03 X38.4418 Y36.5481 I-6.2678 J7.2569 F600.0
N3300 G02 X42.6088 Y36.7585 I2.2747 J-3.6808
N3310 G01 F600
N3320 M05
N3330 G00 Z10.0000
N3340 X63.4674 Y109.9222
N3350 Z4.0000
N3360 M03
N3370 G04 P3
N3380 G01 Z3.0000 F100
N3390 X59.7211 Y106.6111 F600
N3400 G04 P0.25
N3410 X68.7014 Y96.4507
N3420 G02 X58.2398 Y89.9134 I-66.8890 J95.4016 F600.0
N3430 X45.1382 Y86.5339 I-15.7462 J33.9589
N3440 G03 X41.3191 Y83.8940 I-0.0000 J-4.0824
N3450 X33.8948 Y68.7834 I179.8759 J-97.7575
N3460 G02 X29.7474 Y61.5235 I-24.5544 J9.2126
N3470 G01 X28.6642 Y60.2652 F600
N3480 G02 X22.7711 Y55.4703 I-19.3237 J17.7308 F600.0
N3490 X19.3365 Y54.9694 I-2.1849 J2.9565
N3500 X17.5133 Y60.5037 I12.3767 J7.1448
N3510 G03 X13.3111 Y68.2294 I-8.9419 J0.1419
N3520 X6.2713 Y84.1522 I-20.1070 J0.6279
N3530 G02 X0.6941 Y87.2653 I4.0098 J13.7361
N3540 X1.6659 Y91.7293 I2.1634 J1.8668
N3550 X8.1893 Y92.3895 I4.1693 J-8.6366
N3560 G03 X6.3118 Y94.4044 I-5.0207 J-2.7962
N3570 G02 X6.8764 Y96.8955 I1.7422 J0.9147
N3580 X9.5149 Y97.4769 I1.6567 J-1.2406
N3590 G03 X18.1990 Y95.2316 I10.4709 J22.5822
N3600 X30.0093 Y104.8792 I-1.1990 J13.5204
N3610 G02 X43.7934 Y130.6731 I79.8876 J-26.1112
N3620 G01 X44.4757 Y131.4920 F600
N3630 G02 X69.0414 Y143.0924 I24.9327 J-20.9878 F600.0
N3640 X100.0214 Y131.4920 I-0.8981 J-49.5661
N3650 X100.1020 Y130.1814 I-0.6604 J-0.6984
N3660 G03 X84.0516 Y119.2163 I43.0467 J-80.2407
N3670 G02 X85.7286 Y116.2536 I-8.1968 J-6.5957
N3680 X85.5236 Y110.8089 I-5.4033 J-2.5228
N3690 X72.7491 Y99.4208 I-83.7112 J81.0435
N3700 G01 X63.4674 Y109.9222 F600
N3710 M05
N3720 G00 Z10.0000
N3730 X100.7733 Y141.7411
N3740 Z4.0000
N3750 M03
N3760 G04 P3
N3770 G01 Z3.0000 F100
N3780 G02 X99.8596 Y141.9700 I-0.2342 J1.0033 F600.0
N3790 G03 X78.2856 Y153.9362 I-18.4830 J-7.8922
N3800 X46.6669 Y139.4370 I8.2584 J-59.7346
N3810 G02 X45.2651 Y138.9121 I-1.4018 J1.6094
N3820 G01 X44.7113 Y139.0546 F600
N3830 G04 P0.25
N3840 X48.6823 Y149.3721
N3850 G04 P0.25
N3860 X44.0162 Y151.1680
N3870 G04 P0.25
N3880 X40.1524 Y141.1291
N3890 G02 X35.9808 Y153.2551 I7.1152 J9.2283 F600.0
N3900 G01 X50.4351 Y197.1447 F600
N3910 G02 X54.5401 Y199.8520 I3.6723 J-1.1024 F600.0
N3920 X64.0607 Y193.3886 I-5.9659 J-19.0311
N3930 G03 X70.9352 Y194.3759 I2.8100 J4.8608
N3940 X99.4314 Y220.1425 I-231.2492 J284.3867
N3950 G02 X107.8488 Y229.0256 I79.8610 J-67.2456
N3960 G03 X107.3890 Y237.4073 I-26.4255 J2.7539
N3970 G02 X105.5555 Y241.3874 I11.5359 J7.7267
N3980 X106.0604 Y245.3194 I3.5670 J1.5404
N3990 G03 X110.4566 Y252.2617 I-41.1042 J30.8921
N4000 G02 X112.9628 Y252.5578 I1.5557 J-2.4130
N4010 X114.4162 Y250.5454 I-4.8532 J-5.0361
N4020 X114.3253 Y247.6700 I-3.0762 J-1.3419
N4030 G03 X114.1506 Y239.1976 I6.3597 J-4.3691
N4040 G02 X115.5913 Y232.8821 I-4.2674 J-4.2955
N4050 G03 X108.5256 Y192.8233 I339.5748 J-80.5484
N4060 G01 X101.4840 Y193.9906 F600
N4070 G04 P0.25
N4080 X100.6663 Y189.0581
N4090 G04 P0.25
N4100 X108.0036 Y187.8417
N4110 G02 X101.4912 Y142.3508 I-3948.4470 J542.0414 F600.0
N4120 X100.7733 Y141.7411 I-0.9521 J0.3936
N4130 M05
N4140 G00 Z10.0000
N4150 X27.1302 Y231.3408
N4160 Z4.0000
N4170 M03
N4180 G04 P3
N4190 G01 Z3.0000 F100
N4200 X17.9211 Y229.4615 F600
N4210 G02 X9.8679 Y268.9765 I2035.6484 J435.4440 F600.0
N4220 X9.7835 Y274.8234 I16.0416 J3.1555
N4230 G03 X5.9404 Y287.6281 I-12.3604 J3.2693
N4240 G02 X7.5999 Y293.4801 I2.5274 J2.4446
N4250 X12.1418 Y288.5015 I-1.3744 J-5.8149
N4260 G03 X16.3344 Y279.3304 I26.2559 J6.4588
N4270 X21.2257 Y281.0772 I2.2090 J1.5360
N4280 X19.3914 Y285.4445 I-8.1522 J-0.8551
N4290 X15.2862 Y294.9650 I-10.1122 J1.2850
N4300 G02 X20.3784 Y299.4960 I3.2617 J1.4612
N4310 X22.6843 Y295.7227 I-16.2985 J-12.5514
N4320 G03 X26.5275 Y282.2367 I24.9542 J-0.1793
N4330 X32.3271 Y281.6079 I3.4975 J5.1976
N4340 G02 X51.9316 Y286.0275 I23.8390 J-60.0540
N4350 X92.0622 Y278.6442 I-35.2564 J-304.3818
N4360 X121.4044 Y264.9966 I-46.6538 J-138.6723
N4370 X120.2646 Y261.5525 I-1.1399 J-1.5334
N4380 G03 X97.9274 Y259.2416 I-8.7502 J-24.5314
N4390 X84.8705 Y244.4007 I10.5155 J-22.4156
N4400 X80.4237 Y219.2729 I116.1443 J-33.5113
N4410 X54.6298 Y221.8660 I-16.6077 J-35.6158
N4420 X33.4761 Y191.2955 I20.5429 J-36.8190
N4430 G02 X32.5982 Y183.0933 I-359.6715 J34.3513
N4440 X27.0955 Y180.9097 I-3.2259 J0.1040
N4450 X18.7631 Y224.5300 I314.1729 J82.6197
N4460 G01 X28.1300 Y226.4415 F600
N4470 G04 P0.25
N4480 X27.1302 Y231.3408
N4490 M05
N4500 G00 Z10.0000
N4510 X237.2106
N4520 Z4.0000
N4530 M03
N4540 G04 P3
N4550 G01 Z3.0000 F100
N4560 X236.2108 Y226.4415 F600
N4570 G04 P0.25
N4580 X245.5778 Y224.5300
N4590 G02 X237.2454 Y180.9097 I-322.5053 J38.9993 F600.0
N4600 X231.7427 Y183.0933 I-2.2768 J2.2877
N4610 X230.8647 Y191.2955 I358.7936 J42.5535
N4620 G03 X209.7110 Y221.8660 I-41.6966 J-6.2485
N4630 X183.9172 Y219.2729 I-9.1862 J-38.2089
N4640 X179.4703 Y244.4007 I-120.5911 J-8.3835
N4650 X166.4135 Y259.2416 I-23.5724 J-7.5747
N4660 X144.0762 Y261.5525 I-13.5870 J-22.2204
N4670 G02 X142.9364 Y264.9966 I0.0002 J1.9107
N4680 X172.2787 Y278.6442 I75.9960 J-125.0248
N4690 X212.4093 Y286.0275 I75.3870 J-296.9985
N4700 X232.0137 Y281.6079 I-4.2345 J-64.4736
N4710 G03 X237.8134 Y282.2367 I2.3021 J5.8265
N4720 X241.6565 Y295.7227 I-21.1111 J13.3067
N4730 G02 X243.9624 Y299.4960 I18.6043 J-8.7781
N4740 X249.0546 Y294.9650 I1.8304 J-3.0698
N4750 G03 X244.9494 Y285.4445 I6.0071 J-8.2355
N4760 X243.1152 Y281.0772 I6.3180 J-5.2223
N4770 X248.0065 Y279.3304 I2.6823 J-0.2109
N4780 X252.1990 Y288.5015 I-22.0633 J15.6300
N4790 G02 X256.7409 Y293.4801 I5.9163 J-0.8363
N4800 X258.4005 Y287.6281 I-0.8678 J-3.4074
N4810 G03 X254.5573 Y274.8234 I8.5173 J-9.5354
N4820 G02 X254.4730 Y268.9765 I-16.1259 J-2.6914
N4830 X246.4198 Y229.4615 I-2043.7016 J395.9290
N4840 G01 X237.2106 Y231.3408 F600
N4850 M05
N4860 G00 Z10.0000
N4870 X221.7321 Y36.7585
N4880 Z4.0000
N4890 M03
N4900 G04 P3
N4910 G01 Z3.0000 F100
N4920 G02 X225.8990 Y36.5481 I1.8923 J-3.8912 F600.0
N4930 G03 X227.4146 Y34.8918 I7.7835 J5.6005
N4940 G01 X224.0289 Y27.0464 F600
N4950 G04 P0.25
N4960 X228.6195 Y25.0653
N4970 G04 P0.25
N4980 X231.9239 Y32.7223
N4990 G03 X234.0302 Y32.5660 I1.7585 J9.4263 F600.0
N5000 G02 X237.1746 Y28.5132 I-1.4415 J-4.3646
N5010 X234.1001 Y17.5427 I-18.1268 J-0.8360
N5020 X221.3827 Y6.7120 I-21.8052 J12.7219
N5030 G03 X208.8749 Y5.8735 I3.6603 J-148.3051
N5040 G02 X202.7388 Y10.5597 I-0.7451 J5.3849
N5050 G01 X202.4792 Y13.7763 F600
N5060 G04 P0.25
N5070 X212.2460 Y15.3606
N5080 G04 P0.25
N5090 X211.4454 Y20.2959
N5100 G04 P0.25
N5110 X201.8698 Y18.7426
N5120 G04 P0.25
N5130 X201.7885 Y19.2802
N5140 G02 X203.5644 Y27.1856 I6.5610 J2.6782 F600.0
N5150 X210.6218 Y28.0939 I24.8421 J-165.1345
N5160 G03 X217.5395 Y32.4262 I-3.1883 J12.7801
N5170 G02 X221.7321 Y36.7585 I9.2955 J-4.8009
N5180 M05
N5190 G00 Z10.0000
N5200 M05 M30
I am having the very same issue that Tool is. Did you ever get an answer to they sheetcam was not outputting full gcode??
It was a problem with his license and was sorted out off-list. Could you email me or PM me your license serial number. You can find it in Help->about.
Hey Les, I’m having the same problem as well. I have a Jd2 Mad 4x8
When I take the part from sheet cam to the mad gui I have the error “cannot do g1 with zero feed rate” and when I start up sheet cam to run the simulation it won’t simulate anymore, and when I run the post processor and save, and go to the MAD gui it Dose not show a part anymore, and it seems to have minimal code, and I get the same error “cannot do g1 with zero feed rate”
@Caden_TOR - please see Creating a Sheetcam Customer Support file
