Sheetcam layer problems
I have been using Silhouette to edit my images but I changed computers and put Silhouette on the new computer. After that when I would import a drawing from the newly installed Silhouette it would not show up and I finally realized that there is no layer. If I import a drawing from a previously used Silhouette image I have no problem but if I open up that same image and save it I can’t see it in SheetCam and there is no layer when it previously was there.
Do you have any suggestions?
Be sure to try both svg and dxf formats from the CAD, maybe one works where the other won’t. Perhaps they changed their export file format version, I’m just guessing. I think you’re going to have to do the research through that CAD co.
I also use silhouette to do artsy designs. I have never been able to get sheetcam to show the file when I open it.
My work around is I open and save the file in qcad which is the program I use to do mechanical parts.
You may try to make sure you convert your design to a path.
