Sounds like you did not like something I said. And no, I’m certainly not Les secretary, I’m not cute enough.
You say I do not know Mach3 or UCCNC deeply. That’s very interesting coming from you who said:
__
you know that such a CNC does not really exist
when indeed there is. Seems like you do not know them deeply either.
You are correct, I do not know Mach3 deeply (depending on what you mean by deeply).
However, when I first abandoned Mach3 and bought UCCNC I did a great deal of testing. I programmed microcontrollers (no, not Arduino) to inject my custom test signals into UCCNC. I used a logic analyser to test the timing of many inputs and outputs, including the anti-dive which was activated by a slowdown in feedrate. Knowing the stepper steps per linear distance travelled I could see at what speed the anti-dive was activating and de-activating. It worked great and accurately.
I further tested the timing of various synchronous commands (like the THC on/off output for example). The timing of everything was great. Where a bug was found, Cncdrive quickly corrected it. Synchronous torch on/off outputs work fantastic without any interruption to the step pulse stream as proven by the logic analyser testing. I would even program the code an exact known distance and verify the accuracy of UCCNC by counting the step pulses shown in the logic analyser results. UCCNC was pretty much accurate to the step pulse.
So basically I have no idea what else I need from UCCNC. Perhaps you can explain in detail what UCCNC cannot do. And as far as perpendicular leadins on holes (starting at the centre of the hole), that’s exactly what I do when plasma cutting holes. Les added that as a feature some time ago.
As far as I am concerned I know that UCCNC has good control for plasma cutting. I have no idea what “professional” top end requirements you have but it seems like you need to be speaking to the likes of Hypertherm for top end plasma related cam, or perhaps even Siemens or Mazak or one of the other big CNC boys. Then you will get the top dollar professional CNC software that may keep you satisfied.
If there is some big untapped market for your ideas for plasma related cam software, then specify what they are and why they will sell so well. I personally do not understand the need for your wants. If you can explain to me why your “predictive” ideas are better than a built in anti-dive that has proven to work good with testing then I will bow down and consider you my teacher. Until then I remain your skeptic.
At present my THC is not “fast”. I have no need for a PID controlled servo motor driven THC. One day if I’m cutting very thin, quickly warping metal at high speed, then I may need one of those. But all I’ve ever done is a minimum thickness of 3mm and super fast THC has never been needed.
In any case you often have to dampen down the THC response based on the material you are cutting. It’s not one size fits all.
I’m more interested in overall system functionality, like the ability to fire the torch during motion (without motion pause), turn if off during motion, semi-automated mid-cut restarts with torch refire during motion, closed loop hole centre marking at any current level (regardless of set amps) with closed loop control for precise timing to within a hundredth of a second, auto torch refire, puddle jump at pierce point, etc, etc.
And everything controlled from the PC screen. My “slow” THC is just a “black box” that communicates via a noise resistance RS422 connection with the CNC controller, or direct I/O connections for time critical communication.
And to top it off I’ll have my touch screen pendant with as many functions as I desire on an effectively unlimited number of “pages”. Already done a basic prototype screen touch pendant and I like it.
So I’ll pass on the “fast” THC for now and have awesome functionality and control instead, which for me personally is of much greater value. I’m designing my system for what suits me, not to shout out how fast a THC I have.
For plasma cutting Sheetcam does everything I need and so does UCCNC. If it’s less than semi-professional as you suggest, then less than semi-professional is good enough for me. And I also consider them great value for what you get.
