Problems in G-code after post processing
you’re welcome, glad to help.
Assuming your pattern is a single dxf file, once imported as a Part into sheetcam, select the Part, then goto menu Mode / Nesting, then right click on the drawing, select Array and you’ll find what you need, experiment with Arrays.
Once you get duplicate Parts in an Array, ‘connecting’ them, in terms of processing each one sequentially, is automatic unless you apply manual override. This is where toolpath sequencing controls are split between managing it within a Part vs. managing Part to Part. For Part to Part, see Options / ‘Job options’ / Nesting and you’ll find controls to manage sequencing. This is likely what you want since your example above has only one toolpath (contour) within the Part.
If you ever have a dxf with more than one toolpath, you control the sequencing of the toolpaths within a Part via the Operation / ‘Cut path’.
For many of these general sheetcam use cases, see Where to learn Sheetcam
