Probing with a renishaw probe sheetcam
hey ! how are you doing ?
Looking to know if i can configure a probing code with sheetcma ? or should i do it before i strat machining ? I have a 3R system, and wanted to use it with probe system to get repetability.
Or, i thinked about palping it from the cnc, taking the cotation and introduce them into sheetcam machine parameter… Don’t know if it would work ? Thanks folks !!
@Jules.Dep , It should be possible to add a CNC probing motion to the start of any job. The limitation would likely depend on the CNC controller that you are using. Probing could easily be a sequence of motion that could require operator intervention of some kind, such as confirmation of motion, indicators, and physical CNC table events and conditions, so the controller would need to have those provisions with keyboard, button, or touch screen inputs as well as a screen or display for messages.
Sheetcam’s pp role would simply be to place gcodes into the command stream (file) with optional choices as to the makeup of the gcode sequence.
