I have a simple question about using sheetcam with a ShopSaber sidekick 10.
When setting up SheetCam under the machine settings. What Post do I use? There are several that look like something I should use. ShopSabre? Shopsaber plasma?.
WinCNC v3? WinCNC THC? Does anyone use SheetCam with ShopSabre?
We have been using Enroute but would like to move to a more basic and less expensive software. Sorry if this has been covered before. I am a newbee here.
Thank you. I only tried the post “ShopSabre”. The gantry moved to the correct position and crashed the torch into the work. I did not try any of the other posts. The rep. at ShopSabre directed me to try some of the other posts. I will install the one you sent and try that one first.
