Is there a way that I can leave the boxes checked in the lower right toolbar so that I don’t have to manually check box on X or Y every time I open the software?
welcome to the forum.
- Create a job with a typical drawing that you would mirror, and optionally with layer names typical of what your CAD will produce in dxf or svg. If you use layers in CAD for shape grouping where you associate those layers with specific types of cutting operations, then do so and create the cutting operations also.
- Now save the job as a template, File-‘Save job as template’.
- Exit sheetcam and relaunch.
- now File-‘Open job template’. notice your settings for mirroring are retained, and Operations are retained but throw an error because the drawing (and layers) are not saved in templates.
- Now File-‘Import drawing’ and you have instant toolpaths ready to visually inspect and then ‘Run post processor’.
We’ll try that, thanks for the information.
