Just for curiosity sake, I noticed that in the Cut Settings.csv file, the start column all are showing ERROR. anyone have an idea on what these ERRORs mean?
| Column 1 | Column 2 | Column 3 | Column 4 | E | F | G | H | I | J | K | L | M | N | O | P | Q |
| ToolType | Name | Comment | Tool number | Kerf width | Path rules | Plunge rate | Pierce delay | Pause at end of cut | Wiggle length | Pierce height | Cut height | Pierce type | Feed rate | Start | Use leadin settings | Code |
| PlasmaTool | Plasma, 18ga MS 30 Amp 70PSI | 1 | 0.055 in | 60 inches/min | 0.3s | 0.1s | 0.3937 in | 0.08 in | 0.045 in | 0 | 180 inches/min | ERROR | Yes | |||
| PlasmaTool | Plasma, 16ga MS 33 Amp 70PSI | 2 | 0.055 in | 55 inches/min | 0.4s | 0.1s | 0.3937 in | 0.08 in | 0.045 in | 0 | 150 inches/min | ERROR | Yes | |||
| PlasmaTool | Plasma, 14ga MS 35 Amp 70PSI | 3 | 0.055 in | 50 inches/min | 0.6s | 0.1s | 0.3937 in | 0.09 in | 0.045 in | 0 | 115 inches/min | ERROR | Yes | |||
| PlasmaTool | Plasma, 1/8 MS 38 Amp 70PSI | 4 | 0.06 in | 45 inches/min | 0.6s | 0.1s | 0.3937 in | 0.12 in | 0.05 in | 0 | 95 inches/min | ERROR | Yes | |||
| PlasmaTool | Plasma, 10ga MS 39 Amps 70PSI | 5 | 0.06 in | 45 inches/min | 0.7s | 0.1s | 0.3937 in | 0.12 in | 0.05 in | 0 | 85 inches/min | ERROR | Yes | |||
| PlasmaTool | Plasma, 3/16 MS 40 Amps 72PSI | 6 | 0.07 in | 40 inches/min | 0.9s | 0.1s | 0.3937 in | 0.15 in | 0.05 in | 0 | 65 inches/min | ERROR | Yes | |||
| PlasmaTool | Plasma, 1/4 MS 40 Amps 72PSI | 7 | 0.07 in | 40 inches/min | 1.2s | 0.1s | 0.3937 in | 0.15 in | 0.05 in | 0 | 50 inches/min | ERROR | Yes |
