Peck pierce for drilling ??
I would like a peck pierce all the way thru the part.. Like a pilot hole.. Not just peck part.. So I can drill later for plasma cutting ? Any videos on it ?? Or HELP ???
Re: Peck pierce for drilling ??
Draw your holes as circles and put them on a different layer. In SheetCam use the drilling operation instead of the normal plasma contour operation. In the drilling operation make sure the min hole size is less then the circle diameter and the max hole size is greater then the circle size.
