Nesting parts on waste from inside cut.
Posted: Tue Apr 07, 2020 6:18 am
by rodw
Hi guys is it possible to nest parts in the waste inside the 4 large parts here?
- nested cut
- nest.png (88.55 KiB) Viewed 1291 times
I thought I should be able to create a layer somehow but I have not been able to work it out. It would be good not to resort to cutting up the inside waste as another job.
Re: Nesting parts on waste from inside cut.
Posted: Tue Apr 07, 2020 11:08 am
by SeanP
You need to lock those parts, then you can select that inside part to cut first.
In nesting mode right click/ lock
Posted: Tue Apr 07, 2020 12:06 pm
by mancavedweller
Wonderful stuff Sean, I never knew that
Cheers,
Keith
Posted: Tue Apr 07, 2020 12:59 pm
by rodw
Awesome thanks Sean. Much appreciated
- nest2.png (80.26 KiB) Viewed 1279 times
Revised the layout so I can index the sheet to get 10 of the flanges out of a full sheet plus about 100 each of the small ones.
First time I've tried to cut a full sheet like this.... This job has annoyed me becasue I've never had it properly nested,
