Nesting parts on waste from inside cut.
rodw
Post by rodw »
Hi guys is it possible to nest parts in the waste inside the 4 large parts here?
nested cut
nested cut
I thought I should be able to create a layer somehow but I have not been able to work it out. It would be good not to resort to cutting up the inside waste as another job.
SeanP
Re: Nesting parts on waste from inside cut.
Post by SeanP »
You need to lock those parts, then you can select that inside part to cut first.
In nesting mode right click/ lock
mancavedweller
Post by mancavedweller »
Wonderful stuff Sean, I never knew that :P
Cheers,
Keith
rodw
Post by rodw »
Awesome thanks Sean. Much appreciated
Revised the layout so I can index the sheet to get 10 of the flanges out of a full sheet plus about 100 each of the small ones.
First time I've tried to cut a full sheet like this.... This job has annoyed me becasue I've never had it properly nested,
