Bitmaps not loading
Gahhruuba
Bitmaps not loading
Post by Gahhruuba »
So I recently updated to v6.1.71 of sheetcam and now I've found out a bunch of my bitmaps for the toolbars are not loading.
Here is a snippet of the Debugger:
12:13:38: Could not find C:\Program Files\SheetCam TNG Development/resources/Bitmaps/fallback/Open Toolset.png
12:13:38: File not found: Open Toolset
12:13:38: Could not find C:\Program Files\SheetCam TNG Development/resources/Bitmaps/fallback/Save Toolset As.png
12:13:38: File not found: Save Toolset As
12:13:38: Could not find C:\Program Files\SheetCam TNG Development/resources/Bitmaps/fallback/Save Default Toolset.png
12:13:38: File not found: Save Default Toolset
12:13:38: Could not find C:\Program Files\SheetCam TNG Development/resources/Bitmaps/fallback/Load Default Toolset.png
12:13:38: File not found: Load Default Toolset
12:13:38: Could not find C:\Program Files\SheetCam TNG Development/resources/Bitmaps/fallback/ToolImport.png
12:13:38: File not found: ToolImport
12:13:38: Could not find C:\Program Files\SheetCam TNG Development/resources/Bitmaps/fallback/Exit.png
12:13:38: File not found: Exit
12:13:38: Warning: No handler found for image type.
12:13:38: Resource::Bitmap - load failed
12:13:38: Could not find C:\Program Files\SheetCam TNG Development/resources/Bitmaps/fallback/Variable Monitor.png
12:13:38: File not found: Variable Monitor
12:13:38: Could not find C:\Program Files\SheetCam TNG Development/resources/Bitmaps/fallback/Code Editor.png
12:13:38: File not found: Code Editor
Any help would be appreciated! I've checked that folder directory and the fallback folder is nonexistent and some of the file names are inconsistent with what I've got in the regular Bitmaps folder.
Re: Bitmaps not loading
Sorry, I missed this post. The fault only shows up if you use the 'classic' icon set. The latest version should fix the problem.
