I finally got the toolpaths generated and loaded in mach and run on the machine but the torch signal fires at the beginning and doesn't turn off until the end. It doesn't cycle through each separate cut. I have 4 separate start points on the drawing I am using.
http://www.forum.sheetcam.com/viewtopic ... 0866#10866
torch relay start/stop signal
You are using a mill/router post processor instead of a plasma post processor. Go to Options->machine->post processor and choose a suitable plasma post.
http://www.forum.sheetcam.com/viewtopic ... 0868#10868
