Hello All,
Yes everything was working great and I upgraded to windows 10 on my lap top. Well now I am getting closing crashing. when I close the sheetcam.
And where can I send the Debug to? It does not work to send it from the help.
sorry if I mess up typing. I broke a finger today.
and Thank you all.
It said “encountered an internal error” send Debug. after I hit OK it goes to.
next pop up box.-------------
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\Program Files\SheetCam TNG\SheetCam TNG.exe
R6025
- pure virtual function call
OK
next pop up box after hitting ok
SheetCam TNG.exe - Application Error
The exception unknown software exception (0x40000015) occurred in the application at location 0x10074EDF.
Click on OK to terminate the program
OK
then it close’s
Sent a Support file.
20:33:14: Application started
20:33:14: System language is English (U.S.) (en_US)
20:33:14: Currently selected language is en_GB
20:33:14: Currently using English (en_GB)
20:33:14: Loading C:\Program Files\SheetCam TNG\plugins\Autoload\Autoload.lua … OK
20:33:14: Loading C:\Program Files\SheetCam TNG\plugins\BatchProcessing\Quickload.lua … OK
20:33:14: Loading C:\Program Files\SheetCam TNG\plugins\BatchUpdate\BatchUpdate.lua … OK
20:33:14: Loading C:\Program Files\SheetCam TNG\plugins\Calc\calculator.lua … OK
20:33:15: Loading C:\Program Files\SheetCam TNG\plugins\DNC\DNC.dll … OK
20:33:15: Loading C:\Program Files\SheetCam TNG\plugins\dstv\DSTV.dll … OK
20:33:15: Loading C:\Program Files\SheetCam TNG\plugins\dxf\DXF.dll … OK
20:33:15: Loading C:\Program Files\SheetCam TNG\plugins\Excellon\Excellon.dll … OK
20:33:15: Loading C:\Program Files\SheetCam TNG\plugins\gcode\Gcode.dll … OK
20:33:15: Loading C:\Program Files\SheetCam TNG\plugins\hpgl\HPGL.dll … OK
20:33:15: Loading C:\Program Files\SheetCam TNG\plugins\Knife\Knife.dll … Failed: Plugin is unlicensed
20:33:15: Plugin failed to initialise
20:33:15: Loading C:\Program Files\SheetCam TNG\plugins\laser\laser.dll … Disabled
20:33:15: Loading C:\Program Files\SheetCam TNG\plugins\mach\Mach.dll … OK
20:33:15: Loading C:\Program Files\SheetCam TNG\plugins\Quickload\Quickload.lua … OK
20:33:15: Loading C:\Program Files\SheetCam TNG\plugins\RotaryPlasma\RotaryPlasma.dll … Disabled
20:33:16: Loading C:\Program Files\SheetCam TNG\plugins\sim\Sim.dll … OK
20:33:16: Loading C:\Program Files\SheetCam TNG\plugins\svg\SVG.dll … OK
20:33:16: Loading C:\Program Files\SheetCam TNG\plugins\text\Text.dll … OK
20:33:16: Loading C:\Program Files\SheetCam TNG\plugins\USBCNC\USBCNC.dll … OK
20:33:16: Loading C:\Program Files\SheetCam TNG\plugins\VCarve\VCarve.dll … Failed: Plugin is unlicensed
20:33:16: Plugin failed to initialise
20:33:16: Loading C:\Program Files\SheetCam TNG\plugins\Wire\Wire.dll … Disabled
20:33:18: Connected to update server
Thank you all
Greg Grueninger
