Hi guys. This is my first year working with CNC plasma cutter machines using Sheetcam TNG without any issue. Just a couple of days ago when I try to PP or SIM, The program doesn´t work, No SIMs and not code generated (just a few lines M5, M30 and some other few lines). The error say " Feed rate is zero". Do You know how fix this issue or if it is a license issue?
That sounds like a license issue. Try reinstalling the license. If that does not help give me the license serial number. You can find it in Help->about.
I am having the same issue, can someone help?
Try emailing les@sheetcam.com. maybe send him your license file.
