Hi
Having several problems, and am wondering if they are related to the version I am running (4.0.11) After importing a dxf, with a 4 hole bolt pattern, I can only get the simulator to run one of the four holes, then it stops…
Thanks for the help
Caddy
Sounds like:
- You have the min/max hole sizes set wrong? The min must be less
than the hole size and the max greater than the hole size. - Are all the holes on the same layer??? Sheetcam is layer driven.
I am sure there are others, but these the two that most often mess me up.
Art
Country Bubba
At 12:49 PM 6/1/2012, you wrote:
Hi
Thanks for the help
Caddy
