V4.1.7 released
Hi all,
I have just uploaded V4.1.7 to www.sheetcam.com. This release has the following changes:
Fixed: a number of crashes
Changed: Spindle rotation has now moved to the tool definition.
Fixed: Cut order of multi-part jobs was very poorly optimised
Note that as of this version the job file fomat has changed slightly. When loading a job file from a previous version you will get a warning if any of the processes don’t use a clockwise spindle direction. It is up to you to check the tool definition in this case. If you load a job from this version into an earlier version of SheetCam the spindle will always be on and turning clockwise.
