V4.1.20 released
Hi all,
I have just uploaded V4.1.20 to www.sheetcam.com. This version has the following changes:
Fixed: Detail reduction not working on open contours
Added: Parking position in Options->material
Fixed: DXF files losing the last entity if the EOF marker does not have a CRLF after it
Added: Improved collision detection on leadin/out
Note that for parking to work properly you have to modify your post. All posts supplied with SheetCam already have the mod but if you are using a custom post wou will have to modify it yourself or send it to me.
Open the post with a text editor such as Notepad and look for function finish(). In the function look for the following:
endz = safez
rapid()
There also may be the following:
endx = 0
endy = 0
rapid()
Delete these lines and save the post.
