Hi all,
I have just uploaded V4.1.14 to www.sheetcam.com. This version has the folllowing changes:
Changed: drillstart post event changed to drillbegin
Added: Plasma loop size option
Added: Plasma loop collision detection. In most cases, if a loop will gouge it is deleted.
Added: Offsetting open contours. These are always offset to the right of the start point. To reverse the cut side, move the start point.
Note that offsetting open contours is very experimental so expect the unexpected ![]()
WARNING If your job relies on open paths not being offset then this version WILL break it. Check before cutting!
