V4.1.13 released
Hi all,
I have just uploaded V4.1.13 to www.sheetcam.com. This release has the following changes:
Fixed: Drill depth warning ignores start depth
Fixed: Arc leadin not always working on inside offset triangles
Fixed: cancelmodalnumbers function causing SheetCam to crash
Changed: If ‘auto send’ selected, the DNC tool will always be shown when you run the post processor
Fixed: In multi-part mode, clicking on any of the ‘mode’ buttons(tabs, contour properties etc) causes the first part in the list to be selected
Added: ‘Loop corners’ option for plasma cutting.
The loop corners function doesn’t yet perform any collision detection. If you have a complicated drawing, check it doesn’t gouge anywhere.
