V4.0.1 released
Hi all,
I have just uploaded V4.0.1 to www.sheetcam.com. This is a maintenance release of the stable version.
Fixed: DXF import arcs of angle 0 are now interpreted as circles
Fixed: DXF circles sometimes mirrored about X (Z extrusion ignored)
Fixed: Part names defaulting to ‘Untitled’ when reloading a job
Fixed: New tap process visible when in plasma only mode
Fixed: New drill process not visible when in plasma only mode
Fixed: Incorrect outlines displayed when switching between parts
Fixed: Spurious M3 commands in g-code.
Hi all,
I have just fixed a problem with the installer with V4.0.1. It did not set up the SheetCam shortcut correctly. I have corrected this. As SheetCam has not changed in any way I have not changed the version number.
