Hey Les,
Did you forget to show the new version in this one? :})
It still showes V3.1.20 in my setup about!
Art
At 09:48 AM 8/17/2006, you wrote:
Hi all,
I have just uploaded V3.1.21 to > www.sheetcam.com> . This version has
the following changes:Added: Dimension function in scroll screen mode.
Fixed: Spiral pockets with ramping sometimes not cleaning up the rampTo use the dimension tool, make sure you are in scroll screen mode
then right click and select Measure. Click on the first point. If
you click near a vertex (join between two lines/arcs) or the centre
of a circle the dimension will snap to that point. Now when you move
the mouse the coordinate display at the bottom of the screen shows
the X,Y length and the number next to the cursor is the distance
from the start to the cursor. If you click on another point the
dimension start will move to that point. You can cancel
dimensioning by switching to another mode, pressing or or
right clicking and selecting ‘End measuring’Les
