Hi all,
I have just uploaded V3.1.21 to www.sheetcam.com. This version has the following changes:
Added: Dimension function in scroll screen mode.
Fixed: Spiral pockets with ramping sometimes not cleaning up the ramp
To use the dimension tool, make sure you are in scroll screen mode then right click and select Measure. Click on the first point. If you click near a vertex (join between two lines/arcs) or the centre of a circle the dimension will snap to that point. Now when you move the mouse the coordinate display at the bottom of the screen shows the X,Y length and the number next to the cursor is the distance from the start to the cursor. If you click on another point the dimension start will move to that point. You can cancel dimensioning by switching to another mode, pressing or or right clicking and selecting ‘End measuring’
