V3.1.18 released
Hi all,
I have just uploaded V3.1.18 to www.sheetcam.com. This version has the following changes:
John, could you give it a try and see if it fixes your help problem.
Lee, This fixes you part positioning problem. Note that position info was not saved before so it will only work with parts saved with this version or later.
Fixed: Saved part files did not store the position.
Changed: Direction arrow size is now a percentage of tool dia
Changed: Help calls - may fix crashing on some machines?
