Hi all,
I have just uploaded V3.1.17 to www.sheetcam.com. This version has the following changes:
Added: Settings functions to API (see the header file)
Changed: scLoadDrawing now has a quiet parameter to suppress the options box (see the header file and example code). Note if you suppress the options box you need to make sure the ini file is correct for your drawing.
Added: Copy tabs. In tabs mode, right click and select ‘Copy from’. You can only copy from a process that has tabs and uses the same layer. Note if you change the tabs in the original process this will not affect the copied tabs.
