For some reason sheetcam does not set the RPM setting right for the V carve module.
for some reason it is always S1000 instead of the S24000 that I want to work with.
See attachments for the problem.
another V carve problem:
When I array a part with normal operations (pocket, drill etc) everything is fine, when I array a part with a V-carve operation the V carve is not copied to the array.
Hoping to hear from somebody for the solution! See attachment for more info and G code. My settings wrong or just a error in sheetcam?
