If I set up the V-Carving bit I can give a “depth per pass” value.
(I do not mean the Maximum Depth given for the V-Carving Task)
I have a bigger v-bit with a cutter length of 26mm - no matter if save “depth per pass” with 2 mm, it runs into the material all the way down to “Maximum depth”. This can be about 15mm in one pass
I can work around it a bit by having multiple V-Care Tasks with Maximum Depths incementing by 2 mm but that’s not very comfortable…
The ‘depth per pass’ option in the tool definition is ignored by the V carve operation. It is only used by contour and pocket operations.
I took a look at the code and it should not be too bad to add depth per pass. I will investigate further.
I just udpated to the latest 7.0.10 and had the hope that this is now fixed - but looking at the simulation it does not look like
Having a bigger v-Carve bit (90°, D=40mm) and larger text, it partly goes way to deep into the material in one cut.
A parameter for Offset would also be cool!
hmm… but that way, I still need to make sure that the letters are not to massive as then even the smaller bit will go too deep into the material in one step. It is a workaround, but not a solid solution for production
I already wrote:
“I can work around it a bit by having multiple V-Care Tasks with Maximum Depths incementing by 2 mm but that’s not very comfortable…”
To be honest… I did not think about that Sheetcam is 2 1/2D only when asking. The idea was to mill pens, but not “simply round” but with e.g. patterns - but this would require a 3D CAM and a Step File, I assume.
I just installed the current DEv release and gave it a try - this looks great in the simulation. I’ll give it a try on a piece of wood later the day.
Just wonderful - thank you very much!
I have another question please:
I have a mill job with lot of pockets with multiple passes to final depth. How can I tell Sheetcam to NOT lift off Z to a save position after each pass?
This would save the job a lot of time.
ok, that’s of course a reason. But what about adding this with a “use at own risk”-checkbox? I would be really useful when milling a lot of holes…
In some of my jobs it’s around 500 per job…
I can remove this lift manually from gcode, but need to redo this after each e.g. setting change in sheetcam. “Manually” means lot of work, “Search & Replace” has the risk to remove more than I wanted
