Hello,
I just updated and now I am having an issue with the location of my part. Before I would import my drawing (usually a simple illustrator SVG file) and go into Options-Job Options and hit the check box for Use Drawing and the program would place my part (drawing) on the red rectangle. Then I could choose my plasma tool, run the simulation and Post Processor for the plasma cutter.
Now when I load my drawing, it is acting like the Red Square is WAY up and to the right. It draws a blue line (like the cut line i think) to someplace way away, I can’t zoom out enough to see it. Then if i hit the simulation it give the errors. I can Ignore the error, and run the sim. I did it once and let it run for 10 minutes at 500x speed, and the “cutter” never came into view.
I tried to install the latest version 6.0.30 and it did the same thing. I also found 6.9.13 on the PC and tried it, it is also doing the same thing.
Does anyone know what I may have done to cause this? Everything was good yesterday. ha.
Justin
