yes it is fair to say non existent…
if you look at the replies they are just spinning logs and replying to the run of the mill stuff … if you ask a proper technical question … it gets ignored (not the noob setup stuff (my spindle runs when I turn the machine on… the probing doesn’t work etc)
I may be 100% dead wrong but it’s like they shut up shop when covid hit Hungary and are just selling boards.
I think from the discussions had years ago on the active forum when they had a few of us eager users that they used local students from the university to do some of their programming … maybe with covid they have lost this avenue for development.
I feel bad as I recommended their stuff a lot (as they were proactive, helpful etc)… but I’d say in the last year to 18m there has been a change…)
I know they have sold a lot of boards…that’s obviously where the money is… the software is comparable or better than mach3 and easier than mach4 (imo)… so it’s now a cash cow… why develop much further… the money is not really there… development is not going to bring in a flurry of new users…
so for 90% of hobby users it’s great… but if you learn a bit and want a bit more or are ready to do something else (lathe / turn / parametric programming / wizards… or want to modify the screenset… forget it… (the screenset is easy to modify… until you get the next release of software (if that ever happens again…) then the new functions may not work as there are no screenset object settings on your screenset for the new functions…)
I’ve just really struggled with linuxcnc… but that is 100% me as I’ve been lazy with plug and play and windows etc… it mostly just works… and if it doesn’t you can’t do anything about it… with Linux sure you can do anything… if you are a programmer or can get your head in the game with terminal syntax / hardware abstraction layer (hal) then you can do anything.
time to pull my finger out and get to it … as I have no excuse as I already have the hardware (7i76e + thcad10) for plasma… but REALLY I’d like to get my lathe running… as the plasma, mill and router are happy with uccnc as even if CNCdrive shut up shop today but lathe / turn seems to be a problem when you want threading and some simple (parametric) wizards or macros in metric to work… I’ve tried frigging uccnc for lathe but then you hit a snag and realise you are up against it using something that is not designed for that job.
I’d like more time driving the thing than under the bonnet… (I have a fairly expensive (for a hobbyist) semi synergic mig welder just for the purpose of being able to just pick it up set the material thickness and get good welds after not welding for months … ok I may not be able to weld bridges or track rods but better than the cheapo bird poo welder I was using before with poor wire feed control… I just want to be able to feed a CNC lathe gcode and it does what it’s told with a few simple Marcos for facing, parting off / grooving , boring, and turning…)
the Tig welder is nice too… it just welds… no fuss… no under the bonnet time. set and go…
like sheetcam… it just does what it needs to and has a really easy to edit post processor if you want add something or change something in the gcode… great for a hobbyist who dabbles… (plus commercial users too) … idiot proof simple to use, setup etc… when you’ve done it a few times
