torch not shutting off until it moves to home
Having a small issue where the torch will complete its cut, and stay on at the end of the cutting process until it moves to home x0y0 after the cut then it will turn the torch off (using the m5 m30 command). Am using the mach 3 with thc and scriber post processor. Otherwise its working great. Thanks.
Are you sure you are using the mach 3 with thc and scriber post processor? The symptoms you describe sound like you are using a milling/routing post processor.
Yes mach 3 thc with scriber
Does OnPenUP() look like this?
function OnPenUp()
   if toolClass == "MarkerTool" then
      post.Text(" M09\n")
   else
      post.Text (" M05\n")
   if (endDelay > 0) then
      post.Text (" G04 P")
      post.Eol()
Yes it does
How about posting your g-code file so we can see what it’s telling the controller to do?
At the end:
N11110 X0.0000 Y0.0000
N11120 M05 M30
Telling the torch to go to the home position before it turns the torch off.
American flag punisher skull.dxf (32.8 KB)
Can you post the gcode file, not the DXF
*.tap
*.NC
Etc
Open it with notepad, will show the gcode
Edit the post.
function OnFinish()
**********************************<---- to here
endZ = safeZ
OnRapid()
endX = 0
endY = 0
offX = 0
offY = 0
offZ = 0
OnRapid()
post.Text (" M05 M30\n") <---- move this line
Then the torch will shut off before the rapid moves.
Evidently OnPenUp isn’t triggered on the last cut before OnFinish.
Thank you soo much!
Happy to help.
It should be. Just a thought - Are you running a licensed version of SheetCam? The demo version of SheetCam will limit the amount of code generated. In this case it can stop a cut half way through which would leave the torch on.
You SHOULD NOT move the M30 up to the line as shown as M30 as M30 = Program End + REWIND {it rewinds the gcode to the first line…}
you can insert post.Text (" M05\n") at the start of function OnFinish()… but as Les pointed out maybe you have another problem…
Although looking at your gcode it looks like you have M3 where it should be and M5 where it should be… so your problem in my opinion is with Mach3 (do you have a valid licence… with your name registered against it not someone elses name or someone elses business name etc).
Mach3 with a fake licence will do odd things…
  • what motion controller are you using?
N0150 M03
N0160 G04 P0.3
N0170 G01 Z0.1150 F5.0
N0180 X3.7215 Y5.2502 F60.0
N0190 G02 X3.7311 Y5.2333 I-0.0337 J-0.0304
N0200 G01 X3.7323 Y5.2302
N0210 G02 X3.7466 Y5.1412 I-0.3384 J-0.1000
N0220 X3.7517 Y4.8345 I-5.0808 J-0.2374
N0230 X3.7331 Y4.5729 I-1.6042 J-0.0174
N0240 X3.6563 Y4.3090 I-1.3570 J0.2516
N0250 X3.4562 Y3.8454 I-7.2068 J2.8360
N0260 X3.4020 Y3.7498 I-0.5425 J0.2442
N0270 X3.3892 Y3.7417 I-0.0136 J0.0073
N0280 X3.3400 Y3.7663 I0.0091 J0.0797
N0290 G01 X3.3140 Y3.7961
N0300 G02 X3.1240 Y4.1108 I1.3938 J1.0561
N0310 G01 X3.1133 Y4.1359
N0320 G02 X3.0869 Y4.2669 I0.2740 J0.1233
N0330 X3.1171 Y4.3945 I0.4361 J-0.0356
N0340 X3.4305 Y4.9996 I3.0098 J-1.1752
N0350 X3.5880 Y5.2008 I1.1718 J-0.7553
N0360 X3.6637 Y5.2589 I0.2009 J-0.1836
N0370 G01 X3.6677 Y5.2605
N0380 G02 X3.7215 Y5.2502 I0.0201 J-0.0407
N0390 G01 X3.5731 Y5.1161
N0400 M05
Oops. Guess that’s what happens when I read things too fast.
We all do it + read too quick.
Looks like a problem with the machine to me, not responding to the M5’s in the gcode.
But there’s no M5 before it does the homing move at the end. That’s why I thought it wasn’t doing the final OnPenUp.
The OnFinish has two rapids before the final M05. The code doesn’t have an M05 before these two rapids. The only other M05 in the post is in OnPenUp, so it isn’t getting there before it finishes.
That last M5 is hard coded simply to make absolutely sure the spindle/torch is off. In most cases it only has any effect if post processing has been cut short, such as when using SheetCam in evaluation mode.
That’s what I figured, but why is there no final M05 before OnFinish starts? Shouldn’t OnPenUp run before OnFinish?
I’m thinking it must be something with SheetCam not finishing the code. Maybe a license issue, but you’re more familiar with how that all works.
N0150 M03
N0400 M05
N0480 M03
N0730 M05
N0810 M03
N0980 M05
N1060 M03
N1410 M05
N1490 M03
N1660 M05
N1740 M03
<><><> Line #180 around here…
N1840 M05
N1920 M03
N2070 M05
N2150 M03
N2280 M05
N2360 M03
N2550 M05
… gcode seems to be calling the torch to fire + extinguish as required many times… not a sheetcam issue.
You’ll find that with regards to OnFinish() that a lot of the posts are copied from milling post processors … so they don’t really consider the mill spindle going on and off for every PenUp() and PenDn() operation… {copy + paste + edit error… but it has no effect… also if you were running an oxyacetylene torch then you would not want it going on and off either … so the M5 M30 is sort of a confirmation that things are off before the rewind… with Milling you may want to add and M9 too… M5 M9 M30… that way all (common) outputs will be off too
N0010 (Filename: American flag punisher skull.dxf)
N0020 (Post processor: Mach3 THC with scriber.scpost)
N0030 (Date: 21/01/2020)
N0040 G20 (Units: Inches)
N0050 F1
N0060 G53 G90 G40
N0070 (Part: American flag punisher skull)
N0080 (Operation: No Offset, 1, T1: Plasma, 0.05 in kerf)
N0090 G00 X3.5731 Y5.1161
N0100 G31 Z -100 F51.9685
N0110 G92 Z0.0
N0120 G00 Z0.0787
N0130 G92 Z0.0
N0140 G00 Z0.1500
N0150 M03
N0160 G04 P0.3
N0400 M05
N0410 G00 X4.1676 Y3.8814
N0420 Z0.1500
N0430 G31 Z -100 F51.9685
N0440 G92 Z0.0
N0450 G00 Z0.0787
N0460 G92 Z0.0
N0470 G00 Z0.1500
N0480 M03
N0490 G04 P0.3
N0500 G01 Z0.1150 F5.0
N0510 X4.0934 Y3.6957 F60.0
N0520 G02 X4.0671 Y3.7197 I0.0188 J0.0471
N0530 G01 X4.0649 Y3.7235
N0540 G02 X4.0335 Y3.8309 I0.6135 J0.2375
N0550 G03 X3.8949 Y4.2667 I-1.9900 J-0.3930
N0560 G02 X3.8015 Y4.5568 I1.0467 J0.4970
N0570 X3.7813 Y4.8838 I1.6582 J0.2666
N0580 X3.8100 Y5.1344 I1.1933 J-0.0097
N0590 G01 X3.8144 Y5.1507
N0600 G02 X3.8462 Y5.2186 I0.1773 J-0.0417
N0610 X3.8892 Y5.2280 I0.0268 J-0.0196
N0620 X3.9404 Y5.1853 I-0.0918 J-0.1622
N0630 X4.0969 Y4.9758 I-1.3331 J-1.1591
N0640 X4.3825 Y4.4373 I-3.3996 J-2.1481
N0650 X4.4212 Y4.3272 I-0.4786 J-0.2299
N0660 X4.4278 Y4.2039 I-0.6151 J-0.0946
N0670 X4.4103 Y4.0888 I-0.3151 J-0.0110
N0680 X4.3168 Y3.8970 I-1.4646 J0.5951
N0690 X4.1983 Y3.7392 I-0.6190 J0.3414
N0700 X4.1291 Y3.6949 I-0.1281 J0.1241
N0710 X4.0934 Y3.6957 I-0.0168 J0.0478
N0720 G01 X4.1676 Y3.8814
N0730 M05
N0740 G00 X4.6407 Y4.6871
N0750 Z0.1500
N0760 G31 Z -100 F51.9685
N0770 G92 Z0.0
N0780 G00 Z0.0787
N0790 G92 Z0.0
N0800 G00 Z0.1500
N0810 M03
N0820 G04 P0.3
N0830 G01 Z0.1150 F5.0
N0840 X4.6873 Y4.7332 F60.0
N0850 X4.6840 Y4.1733
N0860 G02 X4.6790 Y3.6695 I-30.0213 J0.0469
N0870 X4.6706 Y3.5459 I-0.8663 J-0.0033
N0880 G01 X4.6700 Y3.5432
N0890 G02 X4.6591 Y3.5224 I-0.0283 J0.0016
N0900 X4.6111 Y3.5243 I-0.0214 J0.0644
N0910 G01 X4.6090 Y3.5260
N0920 G02 X4.6060 Y3.5564 I0.1344 J0.0287
N0930 X4.5985 Y4.1794 I18.0802 J0.5290
N0940 G01 Y4.8224
N0950 X4.6879
N0960 X4.6873 Y4.7332
N0970 X4.6218 Y4.7336
N0980 M05
N0990 G00 X6.5614 Y5.5789
N1000 Z0.1500
N1010 G31 Z -100 F51.9685
N1020 G92 Z0.0
N1030 G00 Z0.0787
N1040 G92 Z0.0
N1050 G00 Z0.1500
N1060 M03
N1070 G04 P0.3
N1080 G01 Z0.1150 F5.0
N1090 X6.6930 Y5.4283 F60.0
N1100 G02 X6.4898 Y5.2961 I-0.5670 J0.6492
N1110 G01 X6.4704 Y5.2869
N1120 G02 X6.1434 Y5.1789 I-0.7265 J1.6496
N1130 X5.6567 Y5.0857 I-1.5029 J6.5321
N1140 X5.1146 Y5.0334 I-0.6708 J4.1196
N1150 G01 X5.1048 Y5.0333
N1160 G02 X4.8433 Y5.0508 I-0.0418 J1.3307
N1170 G01 X4.7730 Y5.0661
N1180 G02 X4.2163 Y5.2602 I0.8397 J3.3042
N1190 X4.0344 Y5.3580 I0.4613 J1.0757
N1200 G01 X4.0296 Y5.3616
N1210 G02 X3.9872 Y5.4087 I0.0637 J0.0999
N1220 X3.9805 Y5.4499 I0.0414 J0.0279
N1230 X4.0108 Y5.4864 I0.0787 J-0.0345
N1240 X4.1290 Y5.5560 I0.4551 J-0.6375
N1250 G01 X4.5353 Y5.7549
N1260 G03 X5.0626 Y6.0299 I-4.1477 J8.5953
N1270 X5.5629 Y6.3426 I-4.4909 J7.7422
N1280 G01 X5.6235 Y6.3824
N1290 G02 X6.0849 Y6.6677 I4.3936 J-6.5901
N1300 X6.5985 Y6.8889 I1.2234 J-2.1339
N1310 X6.8365 Y6.9491 I0.5733 J-1.7653
N1320 X6.9774 Y6.9525 I0.0805 J-0.4201
N1330 X7.0950 Y6.8735 I-0.0229 J-0.1612
N1340 X7.1380 Y6.7420 I-0.3283 J-0.1800
N1350 X7.1426 Y6.5288 I-0.8106 J-0.1243
N1360 G01 X7.1418 Y6.5190
N1370 G02 X7.0234 Y5.9737 I-2.5678 J0.2719
N1380 X6.8514 Y5.6119 I-1.4086 J0.4479
N1390 X6.6930 Y5.4283 I-0.7254 J0.4656
N1400 G01 X6.5614 Y5.5789
N1410 M05
N1420 G00 X6.8089 Y4.3932
N1430 Z0.1500
N1440 G31 Z -100 F51.9685
N1450 G92 Z0.0
N1460 G00 Z0.0787
N1470 G92 Z0.0
N1480 G00 Z0.1500
N1490 M03
N1500 G04 P0.3
N1510 G01 Z0.1150 F5.0
N1520 X6.7670 Y4.3933 F60.0
N1530 G02 X6.7683 Y4.5563 I18.5703 J-0.0667
N1540 G01 X6.7721 Y5.2304
N1550 X6.8463
N1560 Y4.5481
N1570 G02 X6.8437 Y4.0319 I-29.7815 J-0.1083
N1580 X6.8357 Y3.8869 I-1.2207 J-0.0054
N1590 X6.8268 Y3.8631 I-0.0383 J0.0007
N1600 G01 X6.8262 Y3.8627
N1610 G02 X6.7831 Y3.8701 I-0.0116 J0.0611
N1620 X6.7785 Y3.8791 I0.0119 J0.0117
N1630 X6.7701 Y3.9784 I0.5575 J0.0972
N1640 X6.7670 Y4.3933 I18.5672 J0.3482
N1650 G01 X6.8089 Y4.3932
N1660 M05
N1670 G00 X5.7685 Y4.3418
N1680 Z0.1500
N1690 G31 Z -100 F51.9685
N1700 G92 Z0.0
N1710 G00 Z0.0787
N1720 G92 Z0.0
N1730 G00 Z0.1500
N1740 M03
N1750 G04 P0.3
N1760 G01 Z0.1150 F5.0
N1770 X5.8143 Y4.3887 F60.0
N1780 X5.8157 Y4.2734
N1790 X5.7255
N1800 X5.7335 Y4.9040
N1810 X5.8077
N1820 X5.8143 Y4.3887
N1830 X5.7673 Y4.4345
N1840 M05
N1850 G00 X6.5553 Y3.6747
N1860 Z0.1500
N1870 G31 Z -100 F51.9685
N1880 G92 Z0.0
N1890 G00 Z0.0787
N1900 G92 Z0.0
N1910 G00 Z0.1500
N1920 M03
N1930 G04 P0.3
N1940 G01 Z0.1150 F5.0
N1950 X6.6561 Y3.6926 F60.0
N1960 G02 X6.6328 Y3.6352 I-0.0573 J-0.0102
N1970 X6.5663 Y3.6208 I-0.0540 J0.0888
N1980 X6.5337 Y3.6292 I-0.0030 J0.0564
N1990 X6.5180 Y3.6600 I0.0374 J0.0384
N2000 G01 X6.5149 Y3.6765
N2010 G02 X6.5324 Y3.7317 I0.0603 J0.0113
N2020 X6.5923 Y3.7520 I0.0593 J-0.0763
N2030 X6.6299 Y3.7448 I0.0093 J-0.0534
N2040 X6.6544 Y3.6995 I-0.0586 J-0.0610
N2050 G01 X6.6561 Y3.6926
N2060 X6.5553 Y3.6747
N2070 M05
N2080 G00 X4.6375 Y8.0514
N2090 Z0.1500
N2100 G31 Z -100 F51.9685
N2110 G92 Z0.0
N2120 G00 Z0.0787
N2130 G92 Z0.0
N2140 G00 Z0.1500
N2150 M03
N2160 G04 P0.3
N2170 G01 Z0.1150 F5.0
N2180 X4.6839 Y8.0976 F60.0
N2190 X4.6801 Y6.1800
N2200 X4.6473 Y6.1753
N2210 G02 X4.6090 Y6.1818 I-0.0105 J0.0542
N2220 X4.6060 Y6.2661 I0.9308 J0.0756
N2230 X4.5985 Y8.1038 I154.0390 J1.5468
N2240 G01 Y10.0153
N2250 X4.6876
N2260 X4.6839 Y8.0976
N2270 X4.6295 Y8.1341
N2280 M05
N2290 G00 X3.5976 Y5.8265
N2300 Z0.1500
N2310 G31 Z -100 F51.9685
N2320 G92 Z0.0
N2330 G00 Z0.0787
N2340 G92 Z0.0
N2350 G00 Z0.1500
N2360 M03
N2370 G04 P0.3
N2380 G01 Z0.1150 F5.0
N2390 X3.6367 Y5.7046 F60.0
N2400 X3.5599 Y5.6958
N2410 Y7.9004
N2420 X3.5603 Y8.8407
N2430 G02 X3.5662 Y9.9105 I67.2737 J0.1641
N2440 G01 X3.5664 Y9.9192
N2450 G02 X3.5750 Y10.0920 I1.7754 J-0.0013
N2460 X3.5815 Y10.1134 I0.0382 J-0.0001
N2470 X3.6285 Y10.1021 I0.0138 J-0.0460
N2480 G01 X3.6289 Y10.1014
N2490 G02 X3.6365 Y10.0545 I-0.1534 J-0.0489
N2500 X3.6444 Y9.7415 I-5.7428 J-0.3016
N2510 X3.6453 Y7.8955 I-218.9801 J-1.0262
N2520 G01 X3.6415 Y5.7052
N2530 X3.6367 Y5.7046
N2540 X3.6221 Y5.8318
N2550 M05
N2560 G00 X3.0514 Y6.5868
N2570 Z0.1500
N2580 G31 Z -100 F51.9685
N2590 G92 Z0.0
N2600 G00 Z0.0787
N2610 G92 Z0.0
N2620 G00 Z0.1500
N2630 M03
N2640 G04 P0.3
N2650 G01 Z0.1150 F5.0
N2660 X3.0358 Y6.7861 F60.0
N2670 X3.0629 Y6.7883
N2680 X3.1253 Y6.9646
N2690 X3.1840 Y6.7883
N2700 X3.3858 Y6.7794
N2710 X3.3097 Y6.7261
N2720 G03 X3.2372 Y6.6630 I0.1962 J-0.2985
N2730 X3.2349 Y6.6455 I0.0124 J-0.0105
N2740 X3.2624 Y6.5532 I0.9004 J0.2180
N2750 G02 X3.2884 Y6.4701 I-0.6964 J-0.2633
N2760 G01 X3.2075 Y6.5314
N2770 X3.1295 Y6.5918
N2780 G02 X2.9843 Y6.4940 I-2.7617 J3.9450
N2790 X2.9784 Y6.4986 I-0.0020 J0.0035
N2800 X2.9902 Y6.5533 I0.1941 J-0.0132
N2810 G03 X3.0084 Y6.6367 I-0.3163 J0.1127
N2820 X2.9828 Y6.6923 I-0.0691 J0.0019
N2830 X2.9423 Y6.7243 I-0.2589 J-0.2863
N2840 G01 X2.8737 Y6.7734
N2850 X3.0358 Y6.7861
N2860 X3.0514 Y6.5868
N2870 M05
N2880 G00 X2.4513 Y7.2203
N2890 Z0.1500
N2900 G31 Z -100 F51.9685
N2910 G92 Z0.0
N2920 G00 Z0.0787
N2930 G92 Z0.0
N2940 G00 Z0.1500
N2950 M03
N2960 G04 P0.3
N2970 G01 Z0.1150 F5.0
N2980 X2.2606 Y7.2805 F60.0
N2990 X2.2784 Y7.3370
N3000 G02 X2.3082 Y7.4082 I0.2751 J-0.0733
N3010 X2.3144 Y7.4077 I0.0030 J-0.0007
N3020 X2.3445 Y7.3325 I-0.4708 J-0.2323
N3030 G01 X2.3680 Y7.2630
N3040 X2.5856 Y7.2542
N3050 X2.5082 Y7.2020
N3060 G03 X2.4267 Y7.1365 I0.2508 J-0.3950
N3070 X2.4232 Y7.1199 I0.0134 J-0.0115
N3080 X2.4463 Y7.0280 I0.4564 J0.0660
N3090 G01 X2.4759 Y6.9422
N3100 X2.4039 Y6.9951
N3110 G03 X2.3188 Y7.0468 I-0.2702 J-0.3489
N3120 G01 X2.3123 Y7.0478
N3130 X2.3097 Y7.0473
N3140 G03 X2.2283 Y7.0000 I0.1462 J-0.3453
N3150 G01 X2.1541 Y6.9468
N3160 X2.2056 Y7.1123
N3170 G03 X2.1922 Y7.1399 I-0.0409 J-0.0028
N3180 X2.1270 Y7.1945 I-0.2862 J-0.2751
N3190 G01 X2.0417 Y7.2556
N3200 X2.2528
N3210 X2.2606 Y7.2805
N3220 X2.4513 Y7.2203
N3230 M05
N3240 G00 X3.1989 Y7.6409
N3250 Z0.1500
N3260 G31 Z -100 F51.9685
N3270 G92 Z0.0
N3280 G00 Z0.0787
N3290 G92 Z0.0
N3300 G00 Z0.1500
N3310 M03
N3320 G04 P0.3
N3330 G01 Z0.1150 F5.0
N3340 X3.2071 Y7.8407 F60.0
N3350 X3.3998 Y7.8329
N3360 X3.3329 Y7.7886
N3370 G03 X3.2565 Y7.7316 I0.2486 J-0.4126
N3380 X3.2395 Y7.6714 I0.0417 J-0.0444
N3390 G01 X3.2628 Y7.5887
N3400 G02 X3.2714 Y7.5415 I-0.1617 J-0.0538
N3410 G01 X3.2709 Y7.5403
N3420 X3.2697 Y7.5398
N3430 X3.2664 Y7.5404
N3440 G02 X3.1994 Y7.5854 I0.1483 J0.2933
N3450 G03 X3.1317 Y7.6258 I-0.1675 J-0.2038
N3460 G01 X3.1264 Y7.6264
N3470 X3.1219 Y7.6253
N3480 G03 X3.0355 Y7.5719 I0.1773 J-0.3836
N3490 G01 X2.9559 Y7.5115
N3500 X2.9834 Y7.5840
N3510 G03 X3.0086 Y7.6712 I-0.3298 J0.1427
N3520 X2.9846 Y7.7364 I-0.0757 J0.0091
N3530 X2.9333 Y7.7786 I-0.2652 J-0.2696
N3540 G01 X2.8566 Y7.8343
N3550 X3.0692
N3560 X3.1255 Y8.0175
N3570 X3.1840 Y7.8417
N3580 X3.2071 Y7.8407
N3590 X3.1989 Y7.6409
N3600 M05
N3610 G00 X2.2397 Y8.2953
N3620 Z0.1500
N3630 G31 Z -100 F51.9685
N3640 G92 Z0.0
N3650 G00 Z0.0787
N3660 G92 Z0.0
N3670 G00 Z0.1500
N3680 M03
N3690 G04 P0.3
N3700 G01 Z0.1150 F5.0
N3710 X2.4368 Y8.3291 F60.0
N3720 G03 X2.4544 Y8.2597 I0.4534 J0.0777
N3730 G01 X2.4761 Y8.1881
N3740 X2.4022 Y8.2412
N3750 G03 X2.3187 Y8.2935 I-0.3366 J-0.4440
N3760 G01 X2.3157 Y8.2942
N3770 X2.3128 Y8.2935
N3780 G03 X2.2262 Y8.2356 I0.2462 J-0.4616
N3790 G02 X2.1681 Y8.1987 I-0.1855 J0.2280
N3800 G01 X2.1654 Y8.2012
N3810 G02 X2.2037 Y8.3322 I1.6063 J-0.3981
N3820 G03 X2.2039 Y8.3749 I-0.0533 J0.0216
N3830 G01 X2.2026 Y8.3774
N3840 G03 X2.1617 Y8.4167 I-0.1281 J-0.0922
N3850 G01 X2.0688 Y8.4862
N3860 X2.1523 Y8.4866
N3870 G03 X2.2248 Y8.4935 I0.0117 J0.2626
N3880 X2.2638 Y8.5295 I-0.0196 J0.0603
N3890 G01 X2.2656 Y8.5333
N3900 G03 X2.2982 Y8.6261 I-1.2609 J0.4940
N3910 G02 X2.3127 Y8.6519 I0.0528 J-0.0129
N3920 X2.3228 Y8.6466 I0.0023 J-0.0079
N3930 X2.3470 Y8.5887 I-0.2674 J-0.1460
N3940 G01 X2.3804 Y8.4945
N3950 X2.5661 Y8.4797
N3960 X2.4995 Y8.4352
N3970 G03 X2.4476 Y8.3919 I0.1109 J-0.1860
N3980 X2.4353 Y8.3385 I0.0565 J-0.0411
N3990 X2.4368 Y8.3291 I0.4549 J0.0683
N4000 G01 X2.2397 Y8.2953
N4010 M05
N4020 G00 X3.1270 Y9.0461
N4030 Z0.1500
N4040 G31 Z -100 F51.9685
N4050 G92 Z0.0
N4060 G00 Z0.0787
N4070 G92 Z0.0
N4080 G00 Z0.1500
N4090 M03
N4100 G04 P0.3
N4110 G01 Z0.1150 F5.0
N4120 X3.2619 Y8.8984 F60.0
N4130 G03 X3.2371 Y8.8732 I0.2262 J-0.2477
N4140 X3.2349 Y8.8560 I0.0122 J-0.0103
N4150 X3.2624 Y8.7639 I0.9068 J0.2204
N4160 G02 X3.2884 Y8.6807 I-0.6906 J-0.2613
N4170 G01 X3.1727 Y8.7693
N4180 G03 X3.1281 Y8.7985 I-0.1551 J-0.1885
N4190 G01 X3.1266 Y8.7982
N4200 G03 X3.0396 Y8.7381 I0.3191 J-0.5552
N4210 G02 X2.9756 Y8.6948 I-0.2684 J0.3284
N4220 G01 X2.9749 Y8.6953
N4230 X2.9746 Y8.6969
N4240 G02 X2.9959 Y8.7753 I0.3906 J-0.0638
N4250 G01 X3.0270 Y8.8654
N4260 G03 X2.8700 Y8.9906 I-1.2760 J-1.4394
N4270 G01 X2.9609 Y8.9911
N4280 G03 X3.0366 Y8.9969 I0.0128 J0.3272
N4290 X3.0797 Y9.0371 I-0.0154 J0.0598
N4300 X3.1058 Y9.1205 I-0.7066 J0.2664
N4310 G02 X3.1216 Y9.1546 I0.0821 J-0.0174
N4320 X3.1334 Y9.1523 I0.0050 J-0.0054
N4330 X3.1554 Y9.0995 I-0.1530 J-0.0949
N4340 G01 X3.1846 Y8.9990
N4350 X3.3821 Y8.9841
N4360 X3.3078 Y8.9336
N4370 G03 X3.2619 Y8.8984 I0.1802 J-0.2828
N4380 G01 X3.1270 Y9.0461
N4390 M05
N4400 G00 X2.2410 Y9.5398
N4410 Z0.1500
N4420 G31 Z -100 F51.9685
N4430 G92 Z0.0
N4440 G00 Z0.0787
N4450 G92 Z0.0
N4460 G00 Z0.1500
N4470 M03
N4480 G04 P0.3
N4490 G01 Z0.1150 F5.0
N4500 X2.2322 Y9.7396 F60.0
N4510 X2.2593 Y9.7408
N4520 X2.3180 Y9.9171
N4530 X2.3804 Y9.7408
N4540 X2.5733 Y9.7260
N4550 X2.5028 Y9.6770
N4560 G03 X2.4478 Y9.6305 I0.1325 J-0.2122
N4570 X2.4363 Y9.5738 I0.0533 J-0.0403
N4580 G01 X2.4371 Y9.5695
N4590 G03 X2.4647 Y9.4800 I1.0612 J0.2780
N4600 G02 X2.4724 Y9.4423 I-0.1170 J-0.0436
N4610 G01 X2.4717 Y9.4416
N4620 X2.4691 Y9.4419
N4630 G02 X2.4024 Y9.4856 I0.1674 J0.3283
N4640 G03 X2.3281 Y9.5246 I-0.1515 J-0.1983
N4650 G01 X2.3228 Y9.5253
N4660 X2.3158 Y9.5243
N4670 G03 X2.2283 Y9.4778 I0.1054 J-0.3037
N4680 G01 X2.1544 Y9.4247
N4690 X2.1821 Y9.4976
N4700 G03 X2.2067 Y9.5813 I-0.3178 J0.1389
N4710 X2.1843 Y9.6388 I-0.0656 J0.0074
N4720 X2.1336 Y9.6786 I-0.2628 J-0.2817
N4730 G01 X2.0575 Y9.7319
N4740 X2.2322 Y9.7396
N4750 X2.2410 Y9.5398
N4760 M05
N4770 G00 X1.4751 Y9.2303
N4780 Z0.1500
N4790 G31 Z -100 F51.9685
N4800 G92 Z0.0
N4810 G00 Z0.0787
N4820 G92 Z0.0
N4830 G00 Z0.1500
N4840 M03
N4850 G04 P0.3
N4860 G01 Z0.1150 F5.0
N4870 X1.3418 Y9.0813 F60.0
N4880 G03 X1.2886 Y9.1247 I-0.5099 J-0.5702
N4890 G01 X1.2130 Y9.1844
N4900 X1.3016
N4910 G03 X1.3779 Y9.1907 I0.0140 J0.2970
N4920 X1.4196 Y9.2300 I-0.0168 J0.0596
N4930 X1.4446 Y9.3137 I-0.5915 J0.2225
N4940 G02 X1.4594 Y9.3477 I0.0809 J-0.0150
N4950 X1.4711 Y9.3449 I0.0048 J-0.0055
N4960 X1.4952 Y9.2898 I-0.1814 J-0.1124
N4970 G01 X1.5297 Y9.1844
N4980 X1.7262
N4990 X1.6490 Y9.1304
N5000 G03 X1.5755 Y9.0663 I0.1972 J-0.3001
N5010 X1.5731 Y9.0482 I0.0133 J-0.0109
N5020 X1.6039 Y8.9482 I0.7641 J0.1803
N5030 G02 X1.6130 Y8.9062 I-0.1056 J-0.0450
N5040 X1.6044 Y8.9019 I-0.0058 J0.0010
N5050 X1.5574 Y8.9301 I0.0751 J0.1787
N5060 G01 X1.4664 Y8.9955
N5070 X1.4041 Y8.9515
N5080 G02 X1.3295 Y8.9024 I-0.3874 J0.5074
N5090 X1.3178 Y8.9021 I-0.0060 J0.0073
N5100 X1.3195 Y8.9238 I0.0305 J0.0085
N5110 G01 X1.3205 Y8.9274
N5120 X1.3640 Y9.0606
N5130 G03 X1.3418 Y9.0813 I-0.5321 J-0.5495
N5140 G01 X1.4751 Y9.2303
N5150 M05
N5160 G00 X0.8341 Y8.5705
N5170 Z0.1500
N5180 G31 Z -100 F51.9685
N5190 G92 Z0.0
N5200 G00 Z0.0787
N5210 G92 Z0.0
N5220 G00 Z0.1500
N5230 M03
N5240 G04 P0.3
N5250 G01 Z0.1150 F5.0
N5260 X0.6434 Y8.6306 F60.0
N5270 X0.6612 Y8.6872
N5280 G02 X0.6910 Y8.7584 I0.2756 J-0.0736
N5290 X0.6972 Y8.7579 I0.0030 J-0.0007
N5300 X0.7273 Y8.6826 I-0.4710 J-0.2324
N5310 G01 X0.7508 Y8.6132
N5320 X0.9664 Y8.6044
N5330 X0.8833 Y8.5449
N5340 G03 X0.8029 Y8.4786 I0.3089 J-0.4562
N5350 X0.8013 Y8.4676 I0.0061 J-0.0065
N5360 X0.8295 Y8.3770 I1.1491 J0.3081
N5370 G01 X0.8588 Y8.2920
N5380 X0.7850 Y8.3451
N5390 G03 X0.6997 Y8.3969 I-0.2979 J-0.3938
N5400 G01 X0.6947 Y8.3981
N5410 X0.6912 Y8.3974
N5420 G03 X0.6099 Y8.3480 I0.1717 J-0.3737
N5430 G01 X0.5340 Y8.2923
N5440 X0.5854 Y8.4609
N5450 G03 X0.5727 Y8.4929 I-0.0370 J0.0039
N5460 X0.5077 Y8.5449 I-0.3031 J-0.3122
N5470 G01 X0.4219 Y8.6058
N5480 X0.6355
N5490 X0.6434 Y8.6306
N5500 X0.8341 Y8.5705
N5510 M05
N5520 G00 X1.4631 Y7.9400
N5530 Z0.1500
N5540 G31 Z -100 F51.9685
N5550 G92 Z0.0
N5560 G00 Z0.0787
N5570 G92 Z0.0
N5580 G00 Z0.1500
N5590 M03
N5600 G04 P0.3
N5610 G01 Z0.1150 F5.0
N5620 X1.3689 Y7.8108 F60.0
N5630 X1.3273 Y7.8411
N5640 G02 X1.2465 Y7.9031 I0.5427 J0.7903
N5650 X1.2398 Y7.9165 I0.0073 J0.0121
N5660 G01 X1.2427 Y7.9190
N5670 G02 X1.2891 Y7.9227 I0.0354 J-0.1489
N5680 G03 X1.3715 Y7.9315 I0.0142 J0.2588
N5690 X1.4182 Y7.9772 I-0.0277 J0.0750
N5700 X1.4441 Y8.0542 I-0.4775 J0.2033
N5710 G02 X1.4599 Y8.0869 I0.0756 J-0.0163
N5720 X1.4716 Y8.0841 I0.0047 J-0.0059
N5730 X1.4938 Y8.0320 I-0.1591 J-0.0988
N5740 G03 X1.5216 Y7.9588 I0.3761 J0.1007
N5750 X1.5715 Y7.9262 I0.0555 J0.0304
N5760 X1.6292 Y7.9228 I0.0498 J0.3614
N5770 G01 X1.7127 Y7.9223
N5780 G03 X1.5674 Y7.8096 I1.9641 J-2.6835
N5790 G01 X1.5984 Y7.7177
N5800 G02 X1.6179 Y7.6504 I-0.3896 J-0.1492
N5810 G01 X1.6180 Y7.6482
N5820 G02 X1.6111 Y7.6400 I-0.0058 J-0.0021
N5830 G01 X1.6094 Y7.6403
N5840 G02 X1.5622 Y7.6712 I0.0867 J0.1839
N5850 G01 X1.5516 Y7.6794
N5860 G03 X1.4734 Y7.7293 I-0.2094 J-0.2419
N5870 G01 X1.4667 Y7.7303
N5880 X1.4641 Y7.7298
N5890 G03 X1.3817 Y7.6805 I0.1565 J-0.3552
N5900 G01 X1.3062 Y7.6251
N5910 X1.3689 Y7.8108
N5920 X1.4631 Y7.9400
N5930 M05
N5940 G00 X0.7125 Y7.2324
N5950 Z0.1500
N5960 G31 Z -100 F51.9685
N5970 G92 Z0.0
N5980 G00 Z0.0787
N5990 G92 Z0.0
N6000 G00 Z0.1500
N6010 M03
N6020 G04 P0.3
N6030 G01 Z0.1150 F5.0
N6040 X0.5146 Y7.2609 F60.0
N6050 G03 X0.5166 Y7.2863 I-0.2056 J0.0296
N6060 X0.4883 Y7.3391 I-0.0724 J-0.0049
N6070 X0.4512 Y7.3669 I-0.2103 J-0.2416
N6080 G01 X0.3846 Y7.4114
N6090 X0.5703 Y7.4262
N6100 X0.6013 Y7.5139
N6110 G02 X0.6279 Y7.5784 I0.3477 J-0.1056
N6120 G01 X0.6292 Y7.5801
N6130 G02 X0.6417 Y7.5804 I0.0063 J-0.0028
N6140 X0.6627 Y7.5278 I-0.1812 J-0.1032
N6150 G03 X0.6907 Y7.4543 I0.3755 J0.1008
N6160 X0.7407 Y7.4217 I0.0556 J0.0305
N6170 X0.7984 Y7.4184 I0.0498 J0.3617
N6180 G01 X0.8819 Y7.4179
N6190 X0.8422 Y7.3883
N6200 G03 X0.7591 Y7.3231 I0.5368 J-0.7701
N6210 X0.7447 Y7.2725 I0.0295 J-0.0357
N6220 G01 X0.7487 Y7.2579
N6230 G02 X0.7787 Y7.1483 I-0.6462 J-0.2359
N6240 X0.7778 Y7.1394 I-0.0092 J-0.0036
N6250 G01 X0.7739 Y7.1398
N6260 G02 X0.6983 Y7.1874 I0.1635 J0.3433
N6270 G03 X0.6343 Y7.2257 I-0.1950 J-0.2533
N6280 G01 X0.6324 Y7.2260
N6290 X0.6278 Y7.2247
N6300 G03 X0.5303 Y7.1612 I0.3056 J-0.5755
N6310 G02 X0.4749 Y7.1260 I-0.2084 J0.2671
N6320 G01 X0.4740 Y7.1261
N6330 G02 X0.5027 Y7.2155 I0.7956 J-0.2061
N6340 G03 X0.5146 Y7.2609 I-0.1937 J0.0750
N6350 G01 X0.7125 Y7.2324
N6360 M05
N6370 G00 X1.6631 Y6.5067
N6380 Z0.1500
N6390 G31 Z -100 F51.9685
N6400 G92 Z0.0
N6410 G00 Z0.0787
N6420 G92 Z0.0
N6430 G00 Z0.1500
N6440 M03
N6450 G04 P0.3
N6460 G01 Z0.1150 F5.0
N6470 X1.6632 Y6.7067 F60.0
N6480 X1.8045 Y6.7066
N6490 G02 X1.8803 Y6.7015 I0.0137 J-0.3654
N6500 X1.8932 Y6.6690 I-0.0017 J-0.0195
N6510 G01 X1.8918 Y6.6669
N6520 G02 X1.8180 Y6.6014 I-0.2513 J0.2089
N6530 G03 X1.7224 Y6.5304 I0.4239 J-0.6703
N6540 G01 X1.7206 Y6.5280
N6550 X1.7207 Y6.5268
N6560 G03 X1.7678 Y6.4911 I0.2182 J0.2385
N6570 X2.4486 Y6.0656 I7.7245 J11.6026
N6580 G01 X2.4848 Y6.0453
N6590 G03 X3.2029 Y5.6789 I6.2306 J11.3240
N6600 G01 X3.2256 Y5.6680
N6610 G02 X3.5142 Y5.5262 I-2.7325 J-5.9244
N6620 X3.5927 Y5.4762 I-0.1846 J-0.3770
N6630 X3.5998 Y5.4598 I-0.0080 J-0.0132
N6640 X3.5663 Y5.4169 I-0.1259 J0.0640
N6650 X3.3441 Y5.2522 I-0.8743 J0.9475
N6660 X3.1729 Y5.1828 I-0.4815 J0.9420
N6670 X2.8422 Y5.1051 I-0.5837 J1.7407
N6680 G01 X2.8345 Y5.1041
N6690 G02 X2.2172 Y5.0861 I-0.4276 J4.0632
N6700 G01 X2.1583 Y5.0908
N6710 G02 X1.4631 Y5.2085 I0.7572 J6.5812
N6720 G01 X1.3966 Y5.2256
N6730 G02 X1.0580 Y5.3488 I0.4563 J1.7808
N6740 X0.7820 Y5.5485 I0.4060 J0.8517
N6750 X0.6005 Y5.8396 I0.6920 J0.6335
N6760 X0.4794 Y6.2754 I1.9867 J0.7870
N6770 X0.4486 Y6.7261 I1.9499 J0.3594
N6780 G01 X0.4490 Y6.7335
N6790 G02 X0.4651 Y6.8601 I0.5861 J-0.0099
N6800 X0.5269 Y6.9925 I0.5565 J-0.1795
N6810 X0.5732 Y7.0362 I0.0927 J-0.0519
N6820 X0.6414 Y7.0400 I0.0407 J-0.1155
N6830 X0.7864 Y6.9984 I-0.2259 J-1.0620
N6840 X1.1372 Y6.8457 I-1.3678 J-3.6203
N6850 G03 X1.4183 Y6.7150 I1.5888 J3.0491
N6860 G01 X1.4312 Y6.7104
N6870 G03 X1.4807 Y6.7263 I0.0167 J0.0331
N6880 G01 X1.4841 Y6.7319
N6890 G03 X1.5188 Y6.8222 I-0.5551 J0.2654
N6900 G02 X1.5558 Y6.9088 I0.3876 J-0.1144
N6910 X1.5754 Y6.9243 I0.0257 J-0.0123
N6920 X1.5963 Y6.9072 I-0.0052 J-0.0277
N6930 X1.6300 Y6.8186 I-0.3741 J-0.1927
N6940 G01 X1.6632 Y6.7067
N6950 X1.6631 Y6.5067
N6960 M05
N6970 G00 X1.4938 Y4.6708
N6980 Z0.1500
N6990 G31 Z -100 F51.9685
N7000 G92 Z0.0
N7010 G00 Z0.0787
N7020 G92 Z0.0
N7030 G00 Z0.1500
N7040 M03
N7050 G04 P0.3
N7060 G01 Z0.1150 F5.0
N7070 X1.5407 Y4.7167 F60.0
N7080 X1.5387 Y4.5368
N7090 X1.5355 Y4.3206
N7100 G02 X1.5277 Y4.2001 I-0.8378 J-0.0060
N7110 X1.5160 Y4.1762 I-0.0342 J0.0018
N7120 X1.4657 Y4.1772 I-0.0239 J0.0628
N7130 G01 X1.4636 Y4.1788
N7140 X1.4607 Y4.1952
N7150 G02 X1.4531 Y4.5429 I5.4802 J0.2943
N7160 G01 Y4.8966
N7170 X1.5426
N7180 X1.5407 Y4.7167
N7190 X1.4751 Y4.7174
N7200 M05
N7210 G00 X2.5416 Y4.7775
N7220 Z0.1500
N7230 G31 Z -100 F51.9685
N7240 G92 Z0.0
N7250 G00 Z0.0787
N7260 G92 Z0.0
N7270 G00 Z0.1500
N7280 M03
N7290 G04 P0.3
N7300 G01 Z0.1150 F5.0
N7310 X2.5233 Y4.9364 F60.0
N7320 X2.5807 Y4.9430
N7330 Y4.2586
N7340 X2.5403
N7350 G02 X2.4998 Y4.2747 I-0.0020 J0.0541
N7360 G01 X2.4983 Y4.2775
N7370 X2.4971 Y4.2858
N7380 G02 X2.4951 Y4.6150 I5.8656 J0.2007
N7390 G01 X2.4991 Y4.9336
N7400 X2.5233 Y4.9364
N7410 X2.5416 Y4.7775
N7420 M05
N7430 G00 X0.7597 Y3.6043
N7440 Z0.1500
N7450 G31 Z -100 F51.9685
N7460 G92 Z0.0
N7470 G00 Z0.0787
N7480 G92 Z0.0
N7490 G00 Z0.1500
N7500 M03
N7510 G04 P0.3
N7520 G01 Z0.1150 F5.0
N7530 X0.7056 Y3.6913 F60.0
N7540 G02 X0.7451 Y3.7027 I0.0399 J-0.0641
N7550 X0.8036 Y3.6596 I-0.0098 J-0.0746
N7560 X0.7685 Y3.5655 I-0.0613 J-0.0307
N7570 X0.6858 Y3.5778 I-0.0279 J0.0964
N7580 G01 X0.6815 Y3.5822
N7590 G02 X0.6779 Y3.6609 I0.0530 J0.0419
N7600 X0.7056 Y3.6913 I0.0676 J-0.0337
N7610 G01 X0.7597 Y3.6043
N7620 M05
N7630 G00 X5.7665 Y7.0590
N7640 Z0.1500
N7650 G31 Z -100 F51.9685
N7660 G92 Z0.0
N7670 G00 Z0.0787
N7680 G92 Z0.0
N7690 G00 Z0.1500
N7700 M03
N7710 G04 P0.3
N7720 G01 Z0.1150 F5.0
N7730 X5.7894 Y6.8603 F60.0
N7740 X5.7261 Y6.8531
N7750 Y9.5257
N7760 X5.8153
N7770 X5.8077 Y6.8624
N7780 X5.7894 Y6.8603
N7790 X5.7665 Y7.0590
N7800 M05
N7810 G00 X6.8124 Y8.4865
N7820 Z0.1500
N7830 G31 Z -100 F51.9685
N7840 G92 Z0.0
N7850 G00 Z0.0787
N7860 G92 Z0.0
N7870 G00 Z0.1500
N7880 M03
N7890 G04 P0.3
N7900 G01 Z0.1150 F5.0
N7910 X6.7941 Y8.6454 F60.0
N7920 X6.8537 Y8.6523
N7930 Y7.8888
N7940 X6.8523 Y7.3869
N7950 G02 X6.8449 Y7.1606 I-2.8787 J-0.0191
N7960 G01 X6.8445 Y7.1570
N7970 G02 X6.8351 Y7.1201 I-0.0838 J0.0017
N7980 G01 X6.8338 Y7.1186
N7990 G02 X6.8060 Y7.1084 I-0.0465 J0.0839
N8000 X6.7831 Y7.1196 I0.0094 J0.0483
N8010 X6.7783 Y7.1299 I0.0129 J0.0122
N8020 X6.7699 Y7.2453 I0.7383 J0.1117
N8030 X6.7683 Y7.8872 I24.1124 J0.3835
N8040 G01 X6.7721 Y8.6429
N8050 X6.7941 Y8.6454
N8060 X6.8124 Y8.4865
N8070 (Operation: Outside Offset, 2, T1: Plasma, 0.05 in kerf)
N8080 M05
N8090 G00 X4.4985 Y-0.1984
N8100 Z0.1500
N8110 G31 Z -100 F51.9685
N8120 G92 Z0.0
N8130 G00 Z0.0787
N8140 G92 Z0.0
N8150 G00 Z0.1500
N8160 M03
N8170 G04 P0.3
N8180 G01 Z0.1150 F5.0
N8190 X4.4819 Y0.0009 F60.0
N8200 X4.6018 Y0.0109
N8210 G03 X4.8099 Y0.0405 I-0.0819 J1.3201
N8220 X4.8892 Y0.0749 I-0.0447 J0.2116
N8230 G01 X4.8896 Y0.0753
N8240 G03 X4.9192 Y0.1240 I-0.0442 J0.0602
N8250 G01 X4.9208 Y0.1306
N8260 X4.9211 Y0.1319
N8270 G03 X4.9543 Y0.3720 I-2.5103 J0.4698
N8280 G01 X4.9654 Y0.4819
N8290 G03 X5.0592 Y1.8784 I-30.5030 J2.7500
N8300 G02 X5.0963 Y2.3959 I9.1073 J-0.3926
N8310 X5.2102 Y2.9141 I2.3017 J-0.2341
N8320 G03 X5.3109 Y3.2439 I-3.9495 J1.3863
N8330 G01 X5.3110 Y3.2444
N8340 G03 X5.3595 Y3.5856 I-1.7602 J0.4241
N8350 G01 X5.3616 Y3.6235
N8360 Y3.6242
N8370 G02 X5.3835 Y3.8932 I2.5816 J-0.0741
N8380 G01 X5.3836 Y3.8949
N8390 G02 X5.3890 Y3.9149 I0.0523 J-0.0034
N8400 X5.4411 Y3.9539 I0.1454 J-0.1398
N8410 G01 X5.4421 Y3.9544
N8420 G02 X5.8362 Y4.0724 I0.4450 J-0.7694
N8430 G01 X5.8367
N8440 G02 X6.1307 Y4.0479 I0.0728 J-0.9027
N8450 X6.2557 Y3.9912 I-0.0879 J-0.3597
N8460 X6.3068 Y3.9220 I-0.0866 J-0.1175
N8470 G01 X6.3072 Y3.9210
N8480 G02 X6.3533 Y3.7301 I-0.6369 J-0.2549
N8490 G01 Y3.7106
N8500 G02 X6.3020 Y3.5566 I-0.3804 J0.0411
N8510 X6.2887 Y3.5429 I-0.0376 J0.0234
N8520 G03 X6.2814 Y3.5356 I0.0137 J-0.0209
N8530 G01 X6.2740 Y3.5242
N8540 X6.2711 Y3.5181
N8550 G03 X6.2942 Y3.4051 I0.1135 J-0.0357
N8560 G01 X6.2975 Y3.4019
N8570 G03 X6.3597 Y3.3762 I0.0744 J0.0916
N8580 G01 X6.3795 Y3.3736
N8590 X6.3814 Y3.3735
N8600 G03 X6.6682 Y3.4366 I0.0286 J0.5532
N8610 G01 X6.6998 Y3.4531
N8620 X6.7005 Y3.4535
N8630 G03 X7.0636 Y3.7958 I-0.5171 J0.9121
N8640 X7.2047 Y4.1351 I-0.7772 J0.5224
N8650 X7.1961 Y4.3910 I-0.5436 J0.1098
N8660 G01 X7.1958 Y4.3921
N8670 G03 X7.1675 Y4.4648 I-0.6343 J-0.2047
N8680 G02 X7.1486 Y4.5881 I0.3032 J0.1097
N8690 X7.1718 Y4.8050 I1.4737 J-0.0483
N8700 X7.2798 Y5.3439 I11.3040 J-1.9851
N8710 G01 X7.3146 Y5.5026
N8720 G03 X7.4698 Y6.2723 I-14.7511 J3.3757
N8730 X7.5518 Y7.2219 I-5.5218 J0.9547
N8740 X7.5495 Y7.5264 I-5.7638 J0.1090
N8750 G01 X7.5494 Y7.5269
N8760 G03 X7.5160 Y7.7132 I-0.7576 J-0.0398
N8770 X6.6402 Y9.2577 I-3.5365 J-0.9847
N8780 X5.9063 Y9.8642 I-2.8196 J-2.6650
N8790 X5.3485 Y10.1711 I-3.2843 J-5.3085
N8800 G01 X5.3478 Y10.1714
N8810 G03 X5.0649 Y10.2779 I-0.9738 J-2.1568
N8820 X4.1607 Y10.4591 I-1.3173 J-4.2276
N8830 G01 X4.1597 Y10.4592
N8840 X4.1091 Y10.4619
N8850 X4.1086
N8860 G03 X3.2802 Y10.4577 I-0.3542 J-11.7136
N8870 X3.1735 Y10.4472 I0.0129 J-0.6818
N8880 G01 X3.1702 Y10.4464
N8890 X3.1679 Y10.4456
N8900 G03 X3.1208 Y10.3755 I0.0165 J-0.0620
N8910 G01 X3.1209 Y10.3731
N8920 X3.1211 Y10.3709
N8930 G03 X3.1492 Y10.2769 I0.3276 J0.0467
N8940 G01 X3.1504 Y10.2746
N8950 G03 X3.2003 Y10.2450 I0.0528 J0.0320
N8960 X3.2738 Y10.2425 I0.0551 J0.5510
N8970 G01 X3.2978
N8980 X3.2789 Y10.2276
N8990 G03 X3.2015 Y10.1618 I0.5031 J-0.6701
N9000 X3.1948 Y10.1366 I0.0173 J-0.0180
N9010 X3.2293 Y10.0291 I2.3712 J0.7021
N9020 G02 X3.2004 Y10.0498 I0.2818 J0.4252
N9030 G01 X3.1996 Y10.0504
N9040 X3.1308 Y10.0990
N9050 G03 X3.1018 Y10.0988 I-0.0144 J-0.0204
N9060 G01 X3.0268 Y10.0450
N9070 X3.0260 Y10.0444
N9080 G02 X3.0046 Y10.0288 I-0.2341 J0.3000
N9090 X3.0220 Y10.0808 I1.1130 J-0.3440
N9100 G03 X3.0357 Y10.1385 I-0.2544 J0.0908
N9110 X3.0332 Y10.1529 I-0.0248 J0.0031
N9120 G01 X3.0297 Y10.1596
N9130 X3.0262 Y10.1648
N9140 G03 X2.9471 Y10.2335 I-0.2921 J-0.2566
N9150 G01 X2.9344 Y10.2424
N9160 X3.0543 Y10.2425
N9170 G03 X3.0782 Y10.2603 I-0.0000 J0.0250
N9180 G01 X3.0960 Y10.3196
N9190 G03 X3.1059 Y10.3910 I-0.1711 J0.0602
N9200 X3.0678 Y10.4285 I-0.0383 J-0.0008
N9210 G01 X3.0588 Y10.4293
N9220 X3.0561
N9230 G03 X2.8953 Y10.4131 I0.0278 J-1.0823
N9240 X2.2718 Y10.2804 I0.9148 J-5.8310
N9250 G01 X2.2713 Y10.2803
N9260 G03 X1.9269 Y10.1406 I0.4984 J-1.7227
N9270 X1.5785 Y9.9183 I0.9702 J-1.9049
N9280 G01 X1.5779 Y9.9178
N9290 X1.5001 Y9.8529
N9300 X1.4996 Y9.8525
N9310 G03 X0.9676 Y9.3558 I7.8675 J-8.9605
N9320 X0.4188 Y8.7891 I9.4829 J-9.7327
N9330 X0.2774 Y8.6180 I1.4271 J-1.3221
N9340 G01 X0.2764 Y8.6164
N9350 G03 X0.1245 Y8.2758 I1.1356 J-0.7106
N9360 X0.0450 Y7.9683 I2.8853 J-0.9099
N9370 X0.0413 Y7.9208 I0.1444 J-0.0350
N9380 X0.0447 Y7.9102 I0.0249 J0.0021
N9390 G01 X0.0458 Y7.9084
N9400 G03 X0.0546 Y7.8996 I0.0215 J0.0127
N9410 G01 X0.0592 Y7.8968
N9420 X0.0656 Y7.8942
N9430 G03 X0.1623 Y7.8830 I0.0874 J0.3327
N9440 G01 X0.1839 Y7.8829
N9450 G03 X0.0820 Y7.7988 I1.2829 J-1.6584
N9460 X0.0748 Y7.7720 I0.0165 J-0.0188
N9470 G01 X0.1129 Y7.6593
N9480 G03 X0.0464 Y7.6901 I-0.1212 J-0.1741
N9490 X0.0046 Y7.6647 I-0.0092 J-0.0321
N9500 G01 X0.0030 Y7.6598
N9510 X0.0022 Y7.6570
N9520 G03 X-0.0144 Y7.5156 I0.8934 J-0.1770
N9530 X-0.0216 Y6.9829 I5.4536 J-0.3397
N9540 X-0.0110 Y6.8915 I0.4591 J0.0071
N9550 G01 X-0.0108 Y6.8909
N9560 G03 X0.0255 Y6.8611 I0.0381 J0.0094
N9570 X0.1149 Y6.8573 I0.0622 J0.4102
N9580 G01 X0.0997 Y6.8463
N9590 G03 X0.0140 Y6.7755 I0.3427 J-0.5015
N9600 X0.0062 Y6.7379 I0.0234 J-0.0245
N9610 X0.0467 Y6.6108 I1.7494 J0.4874
N9620 G01 X0.0425 Y6.6110
N9630 G03 X0.0340 Y6.6099 I-0.0009 J-0.0250
N9640 X0.0067 Y6.5731 I0.0119 J-0.0375
N9650 X0.0081 Y6.4958 I0.3511 J-0.0323
N9660 X0.0601 Y6.0593 I9.5869 J0.9220
N9670 X0.1803 Y5.5396 I3.1222 J0.4485
N9680 X0.5284 Y4.8915 I2.0190 J0.6668
N9690 G01 X0.5674 Y4.8422
N9700 X0.6687 Y4.7171
N9710 X0.5677 Y4.6697
N9720 G03 X0.4233 Y4.5872 I0.3218 J-0.7314
N9730 G01 X0.4220 Y4.5862
N9740 X0.4067 Y4.5736
N9750 G03 X0.3313 Y4.4119 I0.1300 J-0.1591
N9760 X0.3508 Y4.2688 I0.5862 J0.0069
N9770 G02 X0.3730 Y4.1207 I-0.5900 J-0.1643
N9780 X0.3545 Y4.0513 I-0.1216 J-0.0047
N9790 G03 X0.3327 Y3.9669 I0.1253 J-0.0774
N9800 G01 X0.3328 Y3.9602
N9810 Y3.9587
N9820 G03 X0.3714 Y3.7971 I0.5116 J0.0368
N9830 X0.5695 Y3.4778 I0.9836 J0.3892
N9840 X0.6803 Y3.3901 I0.3021 J0.2677
N9850 X0.7568 Y3.3740 I0.0645 J0.1168
N9860 G01 X0.7600 Y3.3745
N9870 X0.7711 Y3.3770
N9880 X0.7733 Y3.3775
N9890 G03 X0.9384 Y3.4505 I-0.2592 J0.8104
N9900 G02 X1.0738 Y3.5075 I0.3180 J-0.5660
N9910 X1.1075 Y3.5063 I0.0149 J-0.0542
N9920 G01 X1.1085 Y3.5059
N9930 G02 X1.2766 Y3.4362 I-0.2775 J-0.9061
N9940 G03 X1.4325 Y3.3779 I0.3076 J0.5856
N9950 G01 X1.4338 Y3.3777
N9960 X1.4384 Y3.3768
N9970 G03 X1.5512 Y3.3904 I0.0370 J0.1675
N9980 X1.6067 Y3.4426 I-0.0576 J0.1169
N9990 G01 X1.6077 Y3.4445
N10000 G03 X1.5894 Y3.5186 I-0.0554 J0.0257
N10010 X1.5090 Y3.5515 I-0.1000 J-0.1297
N10020 X1.4220 Y3.5570 I-0.0751 J-0.4987
N10030 G02 X1.3475 Y3.5711 I0.0003 J0.2058
N10040 G01 X1.3448 Y3.5725
N10050 X1.3435 Y3.5731
N10060 G02 X1.3308 Y3.6019 I0.0092 J0.0212
N10070 G01 X1.3311 Y3.6027
N10080 X1.3332 Y3.6097
N10090 G02 X1.3818 Y3.6822 I0.2227 J-0.0967
N10100 G01 X1.3823 Y3.6827
N10110 X1.3975 Y3.6993
N10120 G02 X1.6652 Y3.9142 I1.0746 J-1.0644
N10130 X2.0697 Y4.1040 I0.8827 J-1.3552
N10140 X2.2545 Y4.1329 I0.1885 J-0.5987
N10150 X2.3581 Y4.1068 I0.0031 J-0.2059
N10160 X2.3982 Y4.0629 I-0.0525 J-0.0882
N10170 X2.4097 Y3.9565 I-0.6734 J-0.1271
N10180 G01 X2.4098 Y3.9560
N10190 G02 X2.4251 Y3.4867 I-12.8725 J-0.6569
N10200 G03 X2.4421 Y3.1241 I5.5859 J0.0792
N10210 X2.4627 Y3.0053 I0.6850 J0.0576
N10220 G02 X2.4965 Y2.7389 I-2.7333 J-0.4820
N10230 X2.5565 Y1.8239 I-23.6958 J-2.0144
N10240 G01 X2.5956 Y1.0022
N10250 G03 X2.6320 Y0.5237 I7.5132 J0.3302
N10260 X2.6737 Y0.3104 I1.1681 J0.1179
N10270 X2.7408 Y0.1894 I0.2958 J0.0847
N10280 G01 X2.7418 Y0.1882
N10290 G03 X2.8410 Y0.1211 I0.2326 J0.2366
N10300 X2.9082 Y0.0987 I0.0899 J0.1577
N10310 G01 X2.9110 Y0.0985
N10320 X2.9137 Y0.0984
N10330 X2.9164 Y0.0986
N10340 G03 X2.9700 Y0.1154 I-0.0138 J0.1374
N10350 X3.0211 Y0.1757 I-0.0356 J0.0820
N10360 G01 X3.0229 Y0.1815
N10370 X3.0234 Y0.1832
N10380 G03 X3.0404 Y0.3134 I-0.6376 J0.1497
N10390 G01 X3.0409 Y0.3216
N10400 Y0.3220
N10410 G03 X3.0499 Y0.7830 I-9.8161 J0.4222
N10420 G01 X3.0508 Y1.6100
N10430 Y2.9684
N10440 G03 X3.0442 Y2.9854 I-0.0250 J0.0000
N10450 G01 X2.9830 Y3.0518
N10460 X2.9821 Y3.0527
N10470 G02 X2.9399 Y3.1057 I0.1882 J0.1931
N10480 G01 X2.9403 Y3.1072
N10490 X2.9411 Y3.1078
N10500 G02 X2.9873 Y3.1210 I0.0413 J-0.0567
N10510 G01 X2.9901
N10520 G03 X3.1944 Y3.2114 I-0.0129 J0.3054
N10530 G01 X3.2036 Y2.0704
N10540 G03 X3.2426 Y0.4369 I67.7029 J0.7974
N10550 G01 X3.2527 Y0.0779
N10560 X3.2530 Y0.0003
N10570 G03 X3.2780 Y-0.0246 I0.0250 J0.0001
N10580 G01 X3.3867
N10590 G03 X3.5326 Y-0.0015 I0.0120 J0.3956
N10600 X3.6389 Y0.0984 I-0.0650 J0.1756
N10610 G01 X3.6403 Y0.1027
N10620 X3.6415 Y0.1076
N10630 X3.6419 Y0.1101
N10640 G03 X3.6580 Y0.2917 I-1.9250 J0.2623
N10650 G01 X3.6685 Y0.4843
N10660 G03 X3.7328 Y2.8109 I-70.0348 J3.0996
N10670 G01 X3.7333 Y3.1801
N10680 X3.9179
N10690 X3.9107 Y2.9871
N10700 G03 X3.8629 Y0.5542 I184.7043 J-4.8410
N10710 X3.8692 Y0.2004 I4.9272 J-0.0903
N10720 X3.8923 Y0.0601 I0.5761 J0.0229
N10730 G01 X3.8930 Y0.0579
N10740 X3.8982 Y0.0449
N10750 G03 X3.9895 Y-0.0229 I0.0983 J0.0369
N10760 X4.0784 Y-0.0173 I0.0306 J0.2224
N10770 G01 X4.0814 Y-0.0163
N10780 G03 X4.1445 Y0.0271 I-0.0689 J0.1679
N10790 X4.1995 Y0.0890 I-0.2317 J0.2609
N10800 G01 X4.2011 Y0.0917
N10810 G03 X4.2214 Y0.1654 I-0.1597 J0.0837
N10820 G01 X4.2249 Y0.2018
N10830 Y0.2025
N10840 G03 X4.2622 Y0.9948 I-21.9974 J1.4311
N10850 X4.3063 Y2.7543 I-118.3677 J3.8481
N10860 G01 X4.3160 Y3.2697
N10870 X4.3489 Y3.2752
N10880 X4.3498 Y3.2753
N10890 G02 X4.4843 Y3.2783 I0.0756 J-0.3713
N10900 X4.6631 Y3.2042 I-0.1144 J-0.5288
N10910 G01 X4.6641 Y3.2036
N10920 G02 X4.7605 Y3.1293 I-0.2325 J-0.4011
N10930 G01 X4.7616 Y3.1283
N10940 X4.7650 Y3.1237
N10950 G02 X4.7534 Y3.1145 I-0.0220 J0.0159
N10960 G01 X4.7517 Y3.1137
N10970 G02 X4.6750 Y3.0963 I-0.0734 J0.1453
N10980 G01 X4.6712 Y3.0961
N10990 G03 X4.5933 Y3.0480 I0.0146 J-0.1108
N11000 G01 X4.5909 Y3.0447
N11010 X4.5899 Y3.0434
N11020 G03 X4.5387 Y2.9234 I0.3145 J-0.2053
N11030 G01 X4.5368 Y2.9163
N11040 X4.5366 Y2.9157
N11050 G03 X4.4947 Y2.5692 I1.5093 J-0.3585
N11060 G01 X4.4937 Y2.5387
N11070 G03 X4.4550 Y0.1134 I141.0871 J-3.4632
N11080 G01 X4.4548 Y0.0258
N11090 X4.2548 Y0.0263
N11100 G00 Z0.0600
N11120 M05 M30
