Hey Les, I’m pretty sure this is going to be another “not possible” question (I seem to be pretty good at those lately), but my goal is to only output a torch height off M code in the output if the next rapid distance is greater than some predetermined value. When we cut a lot of holes in sheets with the laser, it causes a lot of unnecessary movement and slowdowns. Problem is, at the time of OnPenUp(), I don’t know how to get the distance of the next rapid. endX and endY have not been updated at this point yet, so they are still the same as currentX and currentY. Is there anywhere to get the distance of the coming rapid from?
This is the code I currently have and found out the endX/Y are not updated:
if (highSpeed == 1) then
post.NonModalNumber("End X = ", endX * scale, "0.000#") --for debugging purposes
post.NonModalNumber("End Y = ", endY * scale, "0.000#") --for debugging purposes
post.NonModalNumber("Current X = ", currentX * scale, "0.000#") --for debugging purposes
post.NonModalNumber("Current Y = ", currentY * scale, "0.000#") --for debugging purposes
if ((math.sqrt((endX - currentX)^2+(endY - currentY)^2)) * scale > heightOffTol) then
post.Text ("M199\n")
else
highSpeed is a boolean flag and heightOffTol is a decimal, both are custom post variables in the popup dialog.
