Hello all, I have a sidekick 10 by ShopSabre. I have been using Sheetcam for 3 years now fine. Every now and then I come into this problem.
I have (2) code snippets THC OFF (L37) and THC ON (L36).
Normally, for holes smaller than 3" the rule I created makes the cut speed 60% and it turns the THC off at the beginning of the cut then on at the end of the cut.
For some reason today no matter what I do, the code created by Sheetcam keeps putting L36 (THC on) after every hole. Even after I changed the code snippet to be THC off on both start and end. I have created a test of 3 holes and the code is below.
[Filename: CIRCLE TEST.tap]
[Post processor: WinCNC Plasma THC.scpost]
[Date: 23/01/2025]
G20 [Units: Inches]
G90
G9 S10
M65
[Part: CIRCLE TEST]
[Operation: Inside Offset, in, T5: 105A 3/4" Mild (Shielded)]
G0 X24 Y0
L37
M61
G1 X23.75 Y0.0027 F25
L37
G1 X23.65 Y0.0038 F15
G3 I0.35 J-0.0038
G1 X23.8 Y0.0022
L36
G1 X23.9 Y0.0011 F25
M62
G0 X0 Y0
M61
G1 X0.2499 Y0.0054
L37
G1 X0.3499 Y0.0076 F15
G3 I-0.3499 J-0.0076
G1 X0.2 Y0.0043
L36
G1 X0.1 Y0.0022 F25
M62
G0 X12 Y0
M61
G1 X12.2499 Y0.0054
L37
G1 X12.3499 Y0.0076 F15
G1 X12.2 Y0.0043
L36
G1 X12.1 Y0.0022 F25
M62
