Greetings,
When I open a dxf file from AutoCAD that has text in it the text does not show up on the Sheet Cam screen. Any ideas what I might be doint wrong?
Thanks, ![]()
Kerry
Greetings,
Thanks, ![]()
Kerry
Kerry,
If you want to use test in sheetcam, you have to “explode” the test into elements. This can be done not with the normal explode command, but you must use Express Tools “text explode” command to make it work.
Bubber
At 03:58 PM 1/11/2008, you wrote:
Greetings,
Kerry
Thought for Today:
“The trouble with practical jokes is that very often they get elected.”
(Will Rogers)
I guess I’m the only person that didn’t know that. For years I’ve been using corel for my text and then importing the letters into CAD. I’d rather do all the work in one program. Thanks for the tid-bit!!!
AJ
Thanks you for updating us with this interesting information ,great news and your article very Great. It just seems like it’ll look even better in person; all those curves
