Hi
Having problem with using svg import or corel X7 export
I am running sheetcam 6.0.17 and corel X7
Can someone help with settings?
Below are some typical settings BUT I have tried MANY combinations with no luck.
I also tried changing the default DPI setting in Corel, but no luck there.
In Corel X7, I export to svg, not save
At this link https://app.sugarsync.com/iris/wf/D6184542_07790250_820171
you can find a screenshot of my corel settings, svg file created, original CDR file, and sheetcam job file
On Sheetcam import svg settings, I use scaling at 1.1111
I have been using DXF Tool to export to dxf for 3 years but since they do not support X7 it is a pain to use I am wanting to move on to CorelX8, but want to get a handle on converting to SVG and getting away from DXF
Thanks!
Marty
