I started to need to cut thin sheet metal 18g to 22g for my work, but because of material warps I looked into getting a THC. But because my plasma cuts are only 5% of my business I went for the most afordable one … Proma THC 150. I sucessfully set it up in my non-contact cnc plasma cutter. Test moves Z up and down correctly, and my table always cut well without issues prior to adding THC. What happens is when cutting and arc is on THC works up/down correctly. When arc is off and mach3 shows Z going up 15mm for safe travel torch does not go up and in the next cut it will hit material. Everything is connect to earth . Tryed lot’s of things with no result. Please help … I’m keeping a sledge hammer next to the Proma and i don’t want to use it ![]()
I forgot to mention that I’m using Mach3 without THC Post processor.
You might ask your question over on PlasmaSpider.com, there are several people over there that use the Proma THC.
I’ll try that one aswell.
Thanks. They were very helpfull. Problem sorted out.
