some small circles are not executet completely by a grbl plasma setup
hi folks,…
i have some wired behavior when i CAM little holes from an svg or dxf file.
the cam output in sheetcam looks fine, also the preview in bCNC looks ok.
but when i paste the gcode in https://nraynaud.github.io/webgcode/ or send it to the mashine (grbl) the problem is visible.
some circles going to be executed and others with exact the same size are not … only the lead ins are made.
if i tweek the operation settings, lead in length for example, then some circle which where ok before are not ok and vice versa.
postprocessor: grbl plasma (only modifyed the M3 command a bit)
it happens with sheetcam tng dev 6.1.72 win10 and also with sheetcam tng dev 6.1.57 linux
any suggestions?
regards
generated gcode
https://pastebin.com/9ZzSNMGU
