Hey there Les hope you’re doing well! Loving the keyboard shortcuts, I’ve already implemented quite a few.
Some have a few bugs however, here they are below:
-When opening a new part (using assigned CTRL-O to open a saved part, w/ cut op. already assigned), while in nesting mode, it doesn’t un-select whichever part was previously selected. So I have to either click another part & click back on my new part, or click C for contour & then N to get back to nest to un-select the part I don’t want to nest. This doesn’t happen if I go the file—> open part route.
-CTRL C CTRL V for copying/pasting an operation from one part to another doesn’t work- have to right click. A “ghost”
silhouette of the part you’re copying operation from shows, & nothing ever pastes (when using keyboard shorts). Again, if I do the copy/paste operation by right clicking & selecting w/ the mouse what I want, I get smooth flow of the copy paste operation
-When using assigned keyboard short cut of “N” to select “nesting”, and then selecting a part to delete, you cannot
delete it using the “delete” key- have to right click on part & scroll down to delete.
-Using the short cut key “M” for “move to new layer”, after an entity’s moved to a new layer (for use with a different tool), it doesn’t “turn off”. IE: the original layer has that entity still present & being cut.
Below are not bugs, but rather, some other shortcuts which would be cool to add:
-Be able to hit E for “enable all” while clicking within the list of all parts present in a given sheet
-Be able to hit a letter (not D, used up in duplicate) to disable selection of parts when clicking in the programmed worksheet of nested parts
-way to make “X” or “Y” be a shortcut to type in the position unit of part w/o moving mouse over to click edit field (when I rotate a part to nest it using < & > , it loses it’s true zero, so I have to type it in to “reset” it- would be slick to just type X & have it immediately in the coordinate edit field
Hope this all makes sense, again, thanks heaps for this product & all the continued support!!!
