Hi
Not a huge issue but I was wondering if anyone has experienced this “problem” and if so how to resolve it.
When running the simulator on an engraving job, I find that the tool represented in the simulator is much to big in diameter. So much so that I cannot see the letters that the point would be engraving. It makes it difficult to know if the tool point is following the prescribed line. (no offset) Is there a way to make the tool much smaller in diameter (nearly a pinpoint) in the simulator program? I’m hoping this is presented in a way that it makes sense.
Many Thanks
In simulation click on the setup button. In the settings window, reduce the scale size in the ‘Tool diameter’ section.
Thank You Les
