Simulation Woes
I created a simple 4 x 6" rectangle with a 1" dia circle to be cut out randomly placed in the thing. When I ran a simple simulation - setup, then attempted to run it; here’s the message I got:
Post processing…
Warning: WARNING: Feed rate is zero
WARNING: partDrawing1 has no active operation
Post processing completed with 2 warnings
I set a feed rate, kerf width, material thickness. What’s happening?
Jim :confused:
Do you have a plasma cut operation defined? In the ‘Operations’ box on the left hand side you should have at least one operation listed. If you do then make sure the little check box next to the operation should be checked.
If you don’t have an operation defined you need to create one. Go to Help->tutorials and take a look through tutorial 3. That should explain what you need to do.
