Hello Les,
I am using sheetcam since over 4 years now and I am really pleased with the simple handling of the software.
Now I want to insert simple 3D cutting.
I have several line and I want to start on one end on 1mm depth and mill to the other end down to 5mm.
Is there a simple workaround for this?
Maybee to use Part rules or is there a function to not clean up the insert ramp (Ramp Angle).
At the beginning I need this only for POM (cut the complete depth at once), but in the future I will need this feature also for metal (cut in several repetition).
Thank you all in advance.
Regards Finn
