I have just uploaded Dev V6.1.4 to www.sheetcam.com. This release has
teh following changes:
Fixed: Lua editor not opening files correctly when a Lua script throws
an error
Fixed: Path rules sometimes not outputting a acrriage return at the end
of the line
Changed: lots of changes for Linux compatibility
Fixed: Sometimes need to click twice on part check box to enable/disable
the part
Changed: On start path rule text was ambiguous
Fixed: Multiple duplicate would place a part if you click middle-mouse
key or +left mouse key
Fixed: post editor tried saving to program files
Fixed: Perpendicular and tangent leadouts on open contours incorrect.
Fixed: A number of intermittent crashes
Fixed: Missing pipe wall thickness graphic
Fixed: Arc leadin/leaouts sometimes not being generated when they should be.
Fixed: Editing a post causes the post processor to stop working or thow
odd errors.
Fixed: Sim whowing incorrrect Z height when the post is set to ‘top of
table’ or ‘top of spoil board’
Added: Compression in text plugin
Added: In tab edit mode the delete key deletes tabs
The Linux version is available in both 32 bit and 64 bit versions and
should run on most Linux distros.
Yahoo Groups Links
<*> Your email settings:
In the Windows version, SheetCamPlugin.h in the SDK #includes
“…/growarray.h”, which is not in the SDK, which means I can’t compile
For the linux 64 bit version, when I run it it opens a terminal window
instead of a GUI window like the last one did. The linux test version I
had before is 6.1.5 and this is 6.1.4?
Moses
On 05/06/2014 01:39 PM, Les Newell wrote:
Hi all,
I have just uploaded Dev V6.1.4 to > www.sheetcam.com> . This release has
an error
of the line
the part
odd errors.
I’ll email you the file. Did you auto-update to 6.1.4 or install it
manually? Ignore the version numbering on my test versions. It was a bit
random.
On 07/05/2014 15:15, Moses McKnight wrote:
I found a few issues.
“…/growarray.h”, which is not in the SDK, which means I can’t compile >
Moses
Hi all,
an error
of the line
the part
odd errors.
Ignore my last message. I see you meant the installer is command line.
I’ll look into it and see why.
