Could someone help me with understanding and correcting my issue with Sheetcam double cutting a single 1px line in different directions? It only does it with certain imported drawings and I don’t know if I’m importing it incorrectly, or if there is a certain setting I need to adjust within Sheetcam or Inkscape.
The software’s I’m using is Photoshop → Inkscape → Sheetcam - Mach3.
I have this happen every once in a while. It usually happens to me when I have manipulated an object in my drawing program. If you zoom in really close in your drawing program you will see 2 lines, even if your line width is only 1 pixel. Because of these 2 lines, Sheetcam will try to cut one line on the inside, and one line on the outside, thus the 2 directions of cuts. You will need to get rid of one of the 2 lines in your drawing program.
