I built a plasma cutter using an Arduino
using inkscape or laser burn to degisn, I then export as a dxf file I then open sheetcam and adjust parameters 2nd to last operations I pick GRBL for my post processior, run post save send to universal g code sender
I then hit run program,the machine will move to my 4 inner holes then proce
ed to go to the final path and stop but never a torch light ???
if I use lightburn I can cut out traces and names in stencil but nothing with a stop an go.
universal g code sender using a trace cut again works but no stop and goes
ive been at this point for 2 months and am very frustrated with so many post somebody should be able to help me
