Sharp corner loop question
Hi,
When I click the angle loop box, sheet cam will automatically detect corners & do what its suppose to do, but it seems that it doesn’t add loop to all corners especially with large angle such as 120degree. This give problem when I plasma cut thicker plate.
Is there any way that I could force a loop onto large angle corner with larger angles?
Thanks in advance.
Ken
Ken,
Did you ever find a solution to your problem? I seem to be having the exact same issue with large, 120 degree corners.
I’ll look into adding a corner threshold angle option.
