hi there i am trying to import a gasket that i have scanned into the computer, it appears in sheetcam as 2 seperate paths but the is only the 1 outline i want, im unsure how i have made it happen between inkscape and sheetcam.
is it due to the thickness of the lines when i traced it?
thanks
Did you use Inkscape’s automatic tracing? It will put an outline on each side of the line.
In SheetCam switch to edit contours mode (Mode->edit contours), hold down the key and click on the outlines you don’t want. Right-click and select move to layer->new layer.
