Screen problems, Sheetcam under Linux
Hello Les wonder if you can help;
Running Sheetcam 6.1.50 under Suse Leap 42.3 64 Bit in case that makes any difference.
I have had a problem with I believe the last few versions that I can not see the check boxes within tabs or see items such as the Simulator speed control.
So it is difficult to determine which rules I have set, etc. the help text that can pop out when over a button is not seen or if there at all is like a goast outline of the text.
I have tried an install on another Linix PC with the same results.
I do not seem to be able to use Wine or/and Mono to run Sheetcam.exe So I am getting a bit stuck.
Can you help, it does not show any error messages so I am a bit lost what to do.
Adrian
I have had few reports like this. I’ll grab a copy of Suse and see if I can replicate it.
Thanks for that Les, hey I will let you team viewer in if that would help.
For the time I now have a Win 7 desktop available, just copying files across takes time.
Adrian
Thanks for the offer but I’m probably better off installing it here as it will be a lot quicker to run test builds.
Hello Les;
Just wondering if you managed to get a chance to look at this, if there are settings to be changed or if it is await another release?
Cheers
Adrian
I have been doing some experimenting. Are you using KDE or Gnome? In KDE the problem appears to be that the default ‘Breeze’ GTK2 theme is really messed up. In the Application menu go to Settings->System settings->Application style->Gnome application style(GTK). Change the GTK2 theme to Raleigh and hit Apply. SheetCam should now work properly.
I’m not sure where the settings are in Gnome. Let me know if you are using Gnome and I’ll try to find them.
I am using KDE and yes it works, Thank you, thank you, thank you that has made it much better for me, something I will know about for the future.
Adrian
Les, not sure if you would remember this, but after a 4 year away from sheetcam and any plasma cutting I am trying to return. the problem above under linux has returned, I am now using Ubuntu 22.04 LTS which is I believe a Gnome desktop, and again the icons have disappeared when viewing things.
Just wondering if you have seen anything similar?
Adrian
What version are you using? IfI remember correctly the latest version on the website is using GTK3 which should not have this problem.
Hi Les;
I am running Ubuntu 22.04.1 not that sure what versions they are. Gnome is version 42, so I would assume GTK4. The theme is called Yaru. The drop downs, say the one to select machine type rotary or jet do not show the check boxes. None of them do.
With regards trying to contact you via the forum there is a contact admin on the login page, there was no other option I could find.
I am away from the pc for a few days back Sunday evening, so perhaps from then I can assist more in fault finding?
Adrian
Sorry, I meant what version of SheetCam are you using?
I am trying V6.1.57 64 bit.
Adrian
Try the 7.1.20 .deb version.
Will do and let you know.
Adrian
Would not install
adrian@t630:~/Downloads$ sudo apt install ./SheetCamTNG_7.1.20-1_amd64.deb
[sudo] password for adrian:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Note, selecting 'sheetcamtng' instead of './SheetCamTNG_7.1.20-1_amd64.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies.
 sheetcamtng : Depends: libreadline7 but it is not installable
E: Unable to correct problems, you have held broken packages.
May be getting myself tied in knots here, but I found in another thread a libreadline7.zip which I unzipped and installed with
sudo apt install ./libreadline7_7.0-3_amd64.deb
Then I retried sheetcam 7.1.20
This seemed to install. But when I click on the icon to run sheetcam it crashes out, I have clicked to send in a report so hope that helps.
I am now for the time being trying to remove the two packages.
Adrian
If SheetCam asked you to send a report it should have asled you to save a file which you can email to me. It may have been the operating system that asked if you wanted to send a report, in which case I will never see it.
It must have been the system I have a crash file in /var/crash it is 4.32 Meg in size.
The first set of lines are like this:-
ProblemType: Crash
Architecture: amd64
CrashCounter: 1
CurrentDesktop: ubuntu:GNOME
Date: Mon Oct 31 08:40:25 2022
DistroRelease: Ubuntu 22.04
ExecutablePath: /usr/bin/SheetCamTNG-dev
ExecutableTimestamp: 1637254897
ProcCmdline: /usr/bin/SheetCamTNG-dev
ProcCwd: /home/adrian
ProcEnviron:
 LANGUAGE=en_GB:en
 LD_LIBRARY_PATH=<set>
 PATH=(custom, no user)
 XDG_RUNTIME_DIR=<set>
 LANG=en_GB.UTF-8
 SHELL=/bin/bash
ProcMaps:
 556f3b600000-556f3b602000 r-xp 00000000 08:02 2889972                    /usr/bin/SheetCamTNG-dev
 556f3b801000-556f3b802000 r--p 00001000 08:02 2889972                    /usr/bin/SheetCamTNG-dev
 556f3b802000-556f3b803000 rw-p 00002000 08:02 2889972                    /usr/bin/SheetCamTNG-dev
 556f3cacb000-556f3d3a0000 rw-p 00000000 00:00 0                          [heap]
 7fdfe4000000-7fdfe4021000 rw-p 00000000 00:00 0
 7fdfe4021000-7fdfe8000000 ---p 00000000 00:00 0
 7fdfe953c000-7fdfe953d000 r--p 00000000 08:02 2890264                    /usr/lib/x86_64-linux-gnu/libicudata.so.70.1
 7fdfe953d000-7fdfe953e000 r-xp 00001000 08:02 2890264                    /usr/lib/x86_64-linux-gnu/libicudata.so.70.1
 7fdfe953e000-7fdfeb158000 r--p 00002000 08:02 2890264                    /usr/lib/x86_64-linux-gnu/libicudata.so.70.1
 7fdfeb158000-7fdfeb159000 r--p 01c1b000 08:02 2890264                    /usr/lib/x86_64-linux-gnu/libicudata.so.70.1
I don’t see anyhting obvious in the data you’ve given me but if you send me the whole cr4ash dump I may be able to figure out a bit mroe about what is going on.
Hi Les sorry for not seeing a response, no email or anything marked as spam. Guess I have to just keep checking back.
I will send you the file via email.
One other question is, if I have installed in Linux by double clicking on the sheetcam.setup file, how do I uninstall it?
Adrian
