Ok. I’ve been reinstalling some software and I got a response out of Scanything. Now it starts the calibration, finds its spot in the center, then in the bottom RH corner then it runs toward the top and just runs away! Thanks for any help.
I really think this is a great tool if I can get it to work!
Brian’s iPhone ![]()
On Mar 14, 2014, at 1:18 PM, Brian Martin <bmm@agapemail.com (bmm@agapemail.com)> wrote:
The buttons are faded. I had a external controller plugged in but i tried it without and it still wouldn’t let me jog. The drives are enabled in Mach and everything seems to work over there!
Sent from my MacBook Air
On Mar 14, 2014, at 1:07 PM, Les Newell <> les.newell@fastmail.co.uk > (> les.newell@fastmail.co.uk> )> wrote:Are the buttons in the machine window greyed out? If so Scanything is having trouble seeing Mach. Are the drives enabled in Mach?
Are you using the parallel port or an external pulse generator?
On 14/03/2014 15:26, Brian Martin wrote:
No I haven’t been able to jog from Scanything. Mach3 is selected in Scanything and I have the Sheetcam plugin enabled.
Brian’s iPhone >
.,._
,.,_
