Hello, im looking for a hand with Scananything;
I’ve switch everything over to my other laptop, my old laptop that i ran scananything on died ( it was windows
, so i switched everything over to my other laptop that is windows 7. Im currently running a 5x12 custom table using Mach3 and Sheet cam with an external controller, a THC301D via Ethernet, Everything works perfectly table wise.
My problem is that when i hook up my Camera (Supereyes M:b003+), like i always did the X+ and X- are flipped on their axis, But the Y+ and Y- are normal. If i try to rotate the camera to square it with my table it will just invert the issue where the X axis will be correct but the Y Axis is inverted. Its confused me. The thing that really confuses me, is when i just load the image software for the supereyes(not scananything) the X and Y axis are correct while using Mach3, but as soon as i load Scananything the X axis is flipped.
I would really love some help, iv’e spent a few days messing with the .dll files trying to Brute force the issue but im not bright enough to fix it.
Any help would be welcome.
THANK YOU.
Jacob
