Hi Les would you happen to have a version of ScanAnything that runs with PathPilot. It is a fancy version of LinuxCNC running on Linux Mint.
Thanks For the Time, (
TP
TP
If the PathPilot release includes halcompile it should be possible. Scanything can use halcompile to automatically build a custom driver for that specific LinuxCNC version. I have to admit I’ve never tried it though.
There are a LOT of Tormach users out there AND a LOT of Users that use the PathPilot software to run there NON tormach machines. Might be a good time to try it out.
Can you create a no fuss installer to ease the pain of working with LinuxCNC ?
I can get it tested it IF you can create it.
TP
Is PathPilot 32 bit or 64 bit? If you aren’t sure open a command prompt and run the command uname -p
If the result contains the number 64 it’s 64 bit.
HI Less sorry for teh late reply. The latest PathPilot is 64 bit linux mint.
TP
Hi Less,
can you please describe this proces?
Thanks Martin
If halcompile is installed Scanything will automatically build a driver the first time you run it. If halcompile is not available Scanything will fall back to one of it’s pre-built drivers. Every release of LinuxCNC needs it’s own build of the driver so it is quite likely that none of teh pre-built drivers that come with Scanything will work correctly.
